Rubbing and click sound coming from RH wheelwell
Old Sep 9, 2005 | 06:47 AM
NoGreenCard's Avatar
Default Rubbing and click sound coming from RH wheelwell
I took the wheel off to see if theres anything it's rubbing against though I don't know enough about suspensions to tell. It seems to have a rubbing sound and clicks at regular intervals at lower speeds. (under 30)
The control arm was recently replaced but it looks like everythings running fine.
Any Ideas?
Old Sep 9, 2005 | 07:37 AM
AndyD's Avatar
Default Re: Rubbing and click sound coming from RH wheelwell (NoGreenCard)
How old are the axles? Are the axle boots leaking?
That's my guess.
Old Sep 9, 2005 | 07:44 AM
pentaq's Avatar
Default Re: Rubbing and click sound coming from RH wheelwell (AndyD)
ball joints are worn.
Old Sep 9, 2005 | 07:53 AM
SpeedFreak77's Avatar
Default Re: Rubbing and click sound coming from RH wheelwell (pentaq)
Both AndyD and pentaq have good suggestions. Is your car lowered? If so it can cause both of these too go out quicker than usual. If it is happening when you are going straight and when turning I would think it was your ball joints but I would check both if I were you.
tiresias
Sep 21, 2010 10:32 PM
JReal
Suspension & Brakes
Sep 25, 2009 02:29 PM
teewhy55
Aug 27, 2005 11:05 AM
98b18black
20
Jun 16, 2005 12:21 PM
WhitEdRift
Mar 11, 2004 08:48 PM
