oem torque specs for b16
Old Sep 9, 2005 | 04:47 AM
sonnycivic1204's Avatar
Default oem torque specs for b16
Old Sep 9, 2005 | 04:57 AM
hoffman4684's Avatar
For what part of the motor yo'?
Old Sep 9, 2005 | 04:59 AM
im trying to torque the flywheel and clutch and transmisin screw thanks
Old Sep 9, 2005 | 05:18 AM
blaze the chemi's Avatar
Default Re: (sonnycivic1204)
First of all change the topic to the specified question to help other in the future, then buy a Helms so you know what the other torque specs are for the other bolts you need to reinstall. HAVE FUN!
flywheel mounting bolts = 87 ft-lb
clutch = 19 ft-lb
transmission = 47 ft-lb, this is from block to tranny, but the rear mount bracket have special bolts and need to be replaced with a washer, and these are 61 ft-lb.
Old Sep 9, 2005 | 05:19 AM
Echo7847's Avatar
Flywheel mounting bolts - 87 ft lb
Pressure plate to flywheel - 19 ft lb
Old Sep 9, 2005 | 05:29 AM
Ryan.'s Avatar
Default Re: (Echo7847)
good info.
get yourslef a manual and come up with better topic tittles to get faster/better responses
aznej2
Oct 4, 2014 01:35 PM
karnieflk
Jan 4, 2008 05:56 PM
2wheelhunter
Sep 12, 2006 09:36 AM
meagainsttheworld
Sep 5, 2006 01:30 PM
akasen8
Mar 26, 2004 08:02 PM
