Need help with (Suspension)
Old Sep 8, 2005 | 09:28 PM
918-Hatch's Avatar
Colorado <3
Default Need help with (Suspension)
I searched and searched but found nothing. maybe someone could anser or even find a thread about this.. I need to know if eg front Suspension fit on gsr minus the coilovers.
Old Sep 8, 2005 | 09:34 PM
Stoich EG2's Avatar
Default Re: Need help with (918-Hatch)
what parts specifically are you wanting to switch over? if it's the knuckles, your caliper bracket won't line up. everything else should work.
Old Sep 8, 2005 | 09:43 PM
918-Hatch's Avatar
Colorado <3
Default Re: Need help with (ADVAN EG2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ADVAN EG2 &raquo;</TD></TR><TR><TD CLASS="quote">what parts specifically are you wanting to switch over? if it's the knuckles, your caliper bracket won't line up. everything else should work.</TD></TR></TABLE>
I am just going to swap everything over exept the springs (coilovers in this case)
Old Sep 8, 2005 | 09:55 PM
Stoich EG2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 918-Hatch &raquo;</TD></TR><TR><TD CLASS="quote">
I am just going to swap everything over exept the springs (coilovers in this case)</TD></TR></TABLE>
i'm still not sure what you mean by everything. Let's just assume it's EVERYTHING.
The knuckles will fit, but if you plan on using your GSR brake calipers, it will not work with civic knuckles. the reason being is that the GSR caliper mounting bracket is too big to bolt on to the civic knuckle. other than that, you should be fine with everything else.
i doubt you want to use civic brakes on your GSR so don't even think about it
just out of curiosity, why are you doing this?
Old Sep 8, 2005 | 10:14 PM
918-Hatch's Avatar
Colorado <3
Yeah I am going to use civic brake Calopers on it for now.. Just to get it rolling.I bought this car trashed.. https://honda-tech.com/zerothread?id=1292462
Old Sep 9, 2005 | 06:14 AM
918-Hatch's Avatar
Colorado <3
up
Old Sep 10, 2005 | 08:58 PM
918-Hatch's Avatar
Colorado <3
never mind i got it all
xunkn0vvnx
Jan 27, 2007 11:25 PM
K20Death
Honda Fit
Aug 28, 2006 04:24 PM
GREENMOBSTER
Oct 16, 2005 08:51 PM
chronodyne28
Jun 20, 2004 08:17 PM
m0t0rhead
Jul 29, 2003 03:07 AM
