stearing wheel question
Old Sep 8, 2005 | 07:14 PM
rollercosta123's Avatar
Default stearing wheel question
how do i remove the steering wheen out of my 94 eg? can i get step by step please. no stupid answers. what tools(sizes)
Old Sep 8, 2005 | 10:52 PM
Sean @ ESG's Avatar
The new HCI has a how to on removing the wheel and installing a new one with a quick release hub. Check it out.
Old Sep 8, 2005 | 11:49 PM
civic_driver's Avatar
if you have an impact gun it's easy.. just remove the steering wheel cover, and unscrew the bolt in the middle (the big one, i think it's around 16mm or so)
that's about it...easy if you have an impact...
without impact it gets tougher since the wheel will move you have to keep still--i'm not sure if the locking wheel feature will work here...probably will
Old Sep 8, 2005 | 11:55 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (civic_driver)
You will have to take the airbag out first. This is not legal, so I wouldn't advise it.
There are two little bulges on the sides of the wheel. Disconnect the negative terminal first. Take off the little bulges and you should see an torx bolt on either side. Remove these and the airbag should just pull out. Disconnect the harness and install the "short" plug. Undo the bolt. take off wheel.
Old Sep 14, 2005 | 08:36 AM
Default Re: (JDM_Ej)
Old Sep 14, 2005 | 08:55 AM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_driver &raquo;</TD></TR><TR><TD CLASS="quote">if you have an impact gun it's easy.. just remove the steering wheel cover, and unscrew the bolt in the middle (the big one, i think it's around 16mm or so)
without impact it gets tougher since the wheel will move you have to keep still--i'm not sure if the locking wheel feature will work here...probably will</TD></TR></TABLE>
You don't need an impact gun..
Start by removing the air there are 2 torx screws on the left and right side of it and also a cable that is connected at the bottom. Remove the torx screws and the cable at the bottom. The airbag will come out.
Next, take a 19mm socket and remove the nut that is attacked to the steering column. The steering wheel will come off.
Now, the SRS cable reel is attached, there are 3 screws are holding the cable reel down, remove thoise screws and pull off the cable reel. Next, disconnect the cable reel from the SRS cable underneath your dash (this is a bitch to get to).
Everything is off now. But, if you do remove the srs cable reel (mandatory if your installing an aftermarket wheel) you will have to wire your new horn switch directly to your horn, or tap into the horn wire.
Old Sep 14, 2005 | 09:03 AM
Default Re: (JDM-EJ1)
iiight ill try that
Old Sep 14, 2005 | 09:05 AM
JDM-EJ1's Avatar
Default Re: (rollercosta123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rollercosta123 &raquo;</TD></TR><TR><TD CLASS="quote">iiight ill try that</TD></TR></TABLE>
Just make sure you disconnect the battery first, both terminals.
Old Sep 20, 2005 | 07:57 PM
ok
IgnitionZ05
May 22, 2007 07:45 AM
JohnnyLux
Dec 1, 2004 09:12 PM
JamesQ
Aug 18, 2004 07:38 AM
sergio
Jun 13, 2003 12:41 AM
citanest
Jan 8, 2002 06:23 AM
