just bought new header....only has one o2 sensor spot...lil confused....help
Old Sep 8, 2005 | 06:51 PM
redpeppers's Avatar
Default just bought new header....only has one o2 sensor spot...lil confused....help
i have a 97 civic 1.6 non vtec and i just bought a new header 2 put on my car.....the header only has one o2 spot and i was wondering which o2 sensor need to go into it....the first or second......also i was wondering if this will throw any CE lights
Old Sep 8, 2005 | 07:01 PM
perlmeister8's Avatar
Default Re: just bought new header....only has one o2 sensor spot...lil confused....help (redpeppers)
Yes it will throw a cel, you need to get another o2 bung welded in so both are in there. Another option is to just put in the primary o2 sensor and get an o2 simulator for the secondary.
Old Sep 8, 2005 | 09:11 PM
redpeppers's Avatar
Default Re: just bought new header....only has one o2 sensor spot...lil confused....help (perlmeistere81)
where can i get a o2 sim at?
Old Sep 9, 2005 | 06:01 AM
redpeppers's Avatar
bump.....anyone have any other options
Old Sep 9, 2005 | 06:06 AM
search on importparts.com
Old Sep 9, 2005 | 06:07 AM
IHateJDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redpeppers &raquo;</TD></TR><TR><TD CLASS="quote">where can i get a o2 sim at?</TD></TR></TABLE>
o2simulator.com
I would recommend going to a muffler shop and having a 2nd o2 bung welded in though. It's cheap and only takes a moment. Just make sure the primary o2 is in the current bung.
Old Sep 10, 2005 | 08:13 AM
redpeppers's Avatar
Default Re: just bought new header....only has one o2 sensor spot...lil confused....help (IHateJDM)
which is the primary and which is secondary?
Old Sep 10, 2005 | 10:09 AM
redpeppers's Avatar
bump111
Old Sep 10, 2005 | 10:21 AM
undertheradar's Avatar
Yes, plug in the primary (the one before the cat) I'm assuming you have a 96-00 Dx, so it will be the one right on top of the oe exhaust manifold. If you don't plug in the secondary, you will get a cel, but it will not affect the cars performance at all.
Old Sep 10, 2005 | 10:32 AM
redpeppers's Avatar
Default Re: just bought new header....only has one o2 sensor spot...lil confused....help (undertheradar)
i got a CEL p0420.....do u think it is a bad cat?
Old Sep 10, 2005 | 10:35 AM
Is thisafter you installed the header? If so (i'm not sure what that code is) but it will throw a code because the ECU doesn't see the "cleaned" exhaust coming out of the cat via the sensor.
Old Sep 10, 2005 | 10:42 AM
redpeppers's Avatar
no i have not swaped it yet.
Old Sep 10, 2005 | 11:08 PM
redpeppers's Avatar
help...
Old Sep 10, 2005 | 11:43 PM
Jon at Titan's Avatar
The primary Sensor Is the first one before the CAT, Right under the Intake Manifold, the secondary should be after the cat, more than likely placed on the CAT converter
Old Sep 11, 2005 | 12:56 AM
ekhatchling's Avatar
Can you confirm this WAS your old header/cat from your DX?
If so, the aftermarket does not include a cat. You will have to buy a 96-00 EX cat and place it under your car further down the header. Your primary o2 goes on your header on top and the secondary needs to run after your replacement cat.
Old Sep 12, 2005 | 01:04 PM
redpeppers's Avatar
Default Re: just bought new header....only has one o2 sensor spot...lil confused....help (ekmodder)
yeah that is my cat for sure. I am thinking about leaving the cat out....and getting a sim....will that help to loose the CE light if i use only the primary and sim the secondary?
oh yea and i have a CX NOT a DX if that makes a diff...prolly not
Old Sep 12, 2005 | 01:07 PM
IHateJDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redpeppers &raquo;</TD></TR><TR><TD CLASS="quote">yeah that is my cat for sure. I am thinking about leaving the cat out....and getting a sim....will that help to loose the CE light if i use only the primary and sim the secondary?</TD></TR></TABLE>
from what I hear, o2 sims are a hit or miss kind of thing. Some people swear by them, and others cant ever get them to work right. Without a cat, you can still run a second 02, but you need to move it farther down your exhaust where its readings will be far enough off the primary o2's readings.
Old Sep 12, 2005 | 01:08 PM
oh yea and i have a CX NOT a DX if that makes a diff...prolly not</TD></TR></TABLE>
^^Yes that is the idea. Be careful for emissions purposes if you decide to take the cat out. If you are planning on getting a header then be sure and get a high flow cat to put further down your exhaust to stay emissions legal
Old Sep 12, 2005 | 01:49 PM
96CivicBoostCoupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekmodder &raquo;</TD></TR><TR><TD CLASS="quote">Can you confirm this WAS your old header/cat from your DX?
If so, the aftermarket does not include a cat. You will have to buy a 96-00 EX cat and place it under your car further down the header. Your primary o2 goes on your header on top and the secondary needs to run after your replacement cat.</TD></TR></TABLE>
Old Sep 12, 2005 | 01:56 PM
HondaFanatic708's Avatar
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by perlmeistere81 &raquo;</TD></TR><TR><TD CLASS="quote">
^^Yes that is the idea. Be careful for emissions purposes if you decide to take the cat out. If you are planning on getting a header then be sure and get a high flow cat to put further down your exhaust to stay emissions legal </TD></TR></TABLE>**** that, just hold on to the OE parts so you can swap em in quickly and then do your emissions. When you pass, put the other **** back on.
Old Sep 12, 2005 | 03:07 PM
Default Re: just bought new header....only has one o2 sensor spot...lil confused....help (HondaFanatic708)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaFanatic708 &raquo;</TD></TR><TR><TD CLASS="quote">**** that, just hold on to the OE parts so you can swap em in quickly and then do your emissions. When you pass, put the other **** back on.</TD></TR></TABLE>
^^Another option
Old Sep 12, 2005 | 03:24 PM
postman's Avatar
like 10 bucks go to shop and have bung welded make sure they do it at the correct depth to high or low will mess up the sensor
Old Sep 13, 2005 | 11:53 AM
redpeppers's Avatar
Default Re: just bought new header....only has one o2 sensor spot...lil confused....help (postman)
will i have a better preformance w/o the cat on?
Old Sep 13, 2005 | 12:28 PM
IHateJDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redpeppers &raquo;</TD></TR><TR><TD CLASS="quote">will i have a better preformance w/o the cat on?</TD></TR></TABLE>
slightly, but it'll also make your exhaust sound raspy too. Not worth it IMO.
Old Sep 14, 2005 | 09:34 AM
redpeppers's Avatar
like what, a weed eater?
