99 Si Radio Harness
Help ive got a oem radio from a 99-00 civic si im trying to put it into my 93 hatch but it has no wires in the back where can i get the plug????Also their are spots for two plugs but I can only find on of the plugs online is that all I need or do i need both of them????
PLZ HELP
PLZ HELP
maybe honda? just to get the plug.. then find the pinout for the plug. or.. you can go to a junk yard and grab the entire wiring harness for any 99-up honda and mate it to a pre-98 wire harness adapter(sold at stores that sells automotive audio stuff)
he needs the harness that goes into the back of the radio (male), the only harness's they sell at an audio store are to mate a aftermarket radio to the orginal harness (female)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones »</TD></TR><TR><TD CLASS="quote">he needs the harness that goes into the back of the radio (male), the only harness's they sell at an audio store are to mate a aftermarket radio to the orginal harness (female)</TD></TR></TABLE>
um yea.... thats what i said. goto the audio store for the plug! oh well he bought one at best buys!
http://www.the12volt.com that is all you need /thread
EDIT: I even went there for you and found the wiring colors
Constant 12V+ Blue/White
Switched 12V+ Yellow/Red
Ground Black
Illumination Red/Black
Dimmer n/a
Antenna Driver's Pillar
Front Speakers 6 1/2" Doors
Left Front (+) Blue
Left Front (-) Gray/Black
Right Front (+) Red/Green
Right Front (-) Brown/Black
Rear Speakers 6" x 9" Rear Deck
Left Rear (+) Blue/Yellow
Left Rear (-) Gray/White
Right Rear (+) Red/Yellow
Right Rear (-) Brown/White
A rule of thumb for honda stock speaker wiring Blue's/Red's are always positive
Ground Black
Dimmer n/a
Left Front (+) Blue
he needs a "repair" harness (male) for a 99-00 civic, which plugs into the back of his new deck. next, he needs a standard aftermarket radio harness (female) that plugs into the car's radio harness. match the wires in the two new harnesses, and everything is plug and play. the two harnesses shouldn't cost more than $30 from any decent car stereo shop.
^^^^ didn't think about that, because you are using the stock radio. Yeah go to best buy or a mom/pop stereo shop and they should have an aftermarket OEM typr male plug. Then just wire it up with the above diagram
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr_Moos »</TD></TR><TR><TD CLASS="quote">Also their are spots for two plugs but I can only find on of the plugs online is that all I need or do i need both of them????
PLZ HELP</TD></TR></TABLE>
One of those spots is probably for a factory changer. Been a while since I worked car stereo.
did you give them the part number in the picture? that would be retarded if they couldnt fid it by their own part number. Like i said im not using mine anymore so if you need one let me know
I just went to the dealership told them i needed a radio theft repair harness and thats what I got. Give them the part number from that picture and they should be able to get it for you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000DX »</TD></TR><TR><TD CLASS="quote">No, I described to them what I needed. I even bought in the radio. They said I had to buy the whole harness. BTW, how did you find the part number for that piece?</TD></TR></TABLE>
Buy it aftermarket, the dealer will *insert racist comment here* you.
