zc tech question
Old Sep 8, 2005 | 05:47 PM
messeduprex's Avatar
Default zc tech question
ok i need a diagram if anyone has it for the timing belt i need to know how the cam gear line up in relation to the marks on the crankshaft pully i think my belt might of skipped a tooth on the intake side
Old Sep 8, 2005 | 06:23 PM
Kryogen's Avatar
easy and you dont even need a diagram...
Set Crank at TDC, take off Valve cover...look at both cams #1 Cam cap (closest to gears) there are 2 5mm holes through them, the cams have these holes to to get them in line when putting on a belt. A 5mm punch or a allen wrench will work.
Thats it everything will be in alignment.
90civic-ZC
Nov 21, 2011 12:07 PM
ijustchillin
Apr 9, 2007 02:26 PM
janz3n
Oct 25, 2006 07:19 PM
the-one1
Nov 26, 2005 09:58 AM
MonkeyMagic
Apr 12, 2004 06:40 AM
