Don't laugh... Problem replacing headlight bulb. Help?
Old Sep 8, 2005 | 05:31 PM
exile29's Avatar
Default Don't laugh... Problem replacing headlight bulb. Help?
Okay. I feel like a dork, but I need help.
The driver's side headlight bulb went out and I am TRYING to replace it.
I have a 1991 Accord EX. I can't get teh damn retainer ring to turn counter clockwise. Is there a trick to this? Do I have to press in or something?
Thanks
Old Sep 8, 2005 | 05:39 PM
Ev_eezy's Avatar
Default Re: Don't laugh... Problem replacing headlight bulb. Help? (exile29)
I'm trying to remember how the 91's worked. IIRC you have to squeeze the ends of the ring together because there's a clip holding them.
Old Sep 8, 2005 | 06:06 PM
exile29's Avatar
Default Re: Don't laugh... Problem replacing headlight bulb. Help? (Ev_eezy)
I got sick of trying just about everything I could think of, so I placed a screwdriver in onw of the grooves and poped it a few times with a hammer. It came loose! Even better, after I replaced the bulb it snapped back on!
I might have broken something in the process, but the bulb is in there firmly and that's all I care about right now.
Old Sep 8, 2005 | 11:31 PM
CB7VTEC's Avatar
For others who may read this thread, 99% of the time it is the bulb itself that inhibits the retainer from spinning off easily. For example, watch how easy it is to spin that retainer on and off without a bulb in the headlight. Next time push the bulb in as far into the headlight as possible (use something gently for leverage if necessary) as you spin the retainer off with your free hand.
Then again, if you break the retainer, at least its cheap.
Old Sep 9, 2005 | 07:57 AM
AFAccord's Avatar
Default Re: Don't laugh... Problem replacing headlight bulb. Help? (CB7VTEC)
I used to have a 90 accord. Don't you have to twist a retainer, then twist the bulb out?
Old Sep 9, 2005 | 06:18 PM
CB7VTEC's Avatar
Default Re: Don't laugh... Problem replacing headlight bulb. Help? (AFAccord)
Spin the retainer, but no bulb twisting necessary...these are notorious PITA's
Old Sep 9, 2005 | 06:20 PM
MestizoRacer310's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CB7VTEC &raquo;</TD></TR><TR><TD CLASS="quote">Spin the retainer, but no bulb twisting necessary...these are notorious PITA's </TD></TR></TABLE>
Yea, these were quite the pain in the butt. The 94-97 are a bit better....
Old Sep 9, 2005 | 08:52 PM
accrd18's Avatar
Default Re: Don't laugh... Problem replacing headlight bulb. Help? (MestizoRacer310)
can anyone give me a link for the retainers? i dont know where to get them
Old Sep 9, 2005 | 10:25 PM
Default Re: Don't laugh... Problem replacing headlight bulb. Help? (drivinaway367)
You're probably going to have to take them off a set of busted headlights. I don't know if they sell those separately.
Old Sep 10, 2005 | 09:51 AM
CB7VTEC's Avatar
ITEM #5
Zion-I
Jul 16, 2006 09:34 PM
philibuster
Oct 2, 2004 11:08 PM
mynond
Jan 31, 2004 09:29 PM
Beach Accord
Oct 17, 2002 03:55 PM
neo1z
Dec 3, 2001 02:17 PM
