no power to the car
Old Sep 8, 2005 | 03:50 PM
elmanning's Avatar
Default no power to the car
I have a 96 prelude, went to walmart after shopping came back to my car to go home and it would not start. Check the battery its good check the fuses all where good. got a circut tester have power coming to the starter but not going out to the rest of the car. Have not got a clue whats wrong. Any ideas would help
Old Sep 8, 2005 | 04:56 PM
Sabbotage's Avatar
Default Re: no power to the car (elmanning)
Is your fuel pup coming on when you turn on the ignition? If not its probably your main relay.
Old Sep 8, 2005 | 07:14 PM
elmanning's Avatar
Default Re: no power to the car (Sabbotage)
Not at the time, went back a couple hours later and it started right up, its going to honda dealership in the morning to find out the problem.
Old Sep 8, 2005 | 07:16 PM
tdo's Avatar
tdo
check your grounds. might have some biuld up .. just clean it.
Old Sep 9, 2005 | 10:30 AM
Sabbotage's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elmanning &raquo;</TD></TR><TR><TD CLASS="quote">went back a couple hours later and it started right up.</TD></TR></TABLE>
i can almost bet that its your main relay then. Thats usually what happens. When the car is cold it starts right up and when its hot it wont start. It has to do with the expansion and contraction of the solder joints due to hot and cold in the main relay. Resoldering it probably would fix your problem.
E Es Won
Honda Civic (2001 - 2005)
Dec 13, 2013 05:06 PM
Ecskater1313
10
Oct 25, 2007 08:21 AM
90_civic_Si
Dec 7, 2006 11:56 AM
eltigre
23
Jun 7, 2006 12:16 PM
crexer
Aug 30, 2004 07:16 PM
