need help quick fast and in a hury..b2 to b7!!
ok im about to do this swap...the b7 is mpfi and my b2 is dpfi..FOR RIGHT NOW, im gunna convert the b7 to dpfi and deal with the HP loss...i read you need a diffrent dizzy to swap the dpfi for mpfi...so my question is will my b2 dizzy fit in the b7???i would think it would since its the exact same motor other then the mpfi and sensors..THANKS
Don't know if this is any help I put a z1 head on a b7 block in a dpfi car took out the b2, I used the b2 dizzy and everything works except I had to file the top bolt hole and the other 2 bolt holes on the dizzy did not line up but I used the top and used washers on the bottom 2 btw I left the dpfi and did not convert to mpfi so I would say yes the b2 dizzy will fit and work but you might have to change the spark plug wires on the dizzy i.e use the b7 wires on the b2 cap they should fit
yeah im hopin it will all work...b2 ecu, b2 harness, b2 dizzy and dpfi...i kno the b7 has a crank angle sensor but i wouldnt think i would need that for it to run since thats for the b7 harness and from what i understand the CAS is to detech TDC for injector timing and shyt like that
Ghett0_ed
Feb 10, 2009 07:59 PM
Xemu
Aug 24, 2006 01:51 AM
