98 Civic Hatchback - how to remove center console cover?
i need to know how to remove the center console cover. the one with the ac / radio .. the whole oval shaped piece.
i thought all you had to do is pull on it and it pops out. but it seems to be held in by something on the left top side. the side that has the caution light blinker switch.
any help / info would be great
thanks..
thanks..
one screw unerneat by the cig lighter, then take out your hazard light switch assembly, and your rear defrost assembly there are screws behind there, and i forget exactly where the others are, but they are easy to find
and also remove that plastic cigarette lighter panel right beneath, and i think there should be some screws there too
edit. already posted
Modified by ntm at 7:10 PM 9/8/2005
evilcivilian
Feb 12, 2008 04:09 PM
