installing axles after dropping b-series motor
Old Feb 26, 2002 | 08:32 PM
E-lude78's Avatar
Default installing axles after dropping b-series motor
Have you guys removed the center ring in the hub and the dust seal on the outer joints of the axles? How do you remove them? As quoted from the HAsport site:
"For a good fit, the axles and car will have to be modified by removing the spacer in the hub and removing the dust seal on the outer joint."
Old Feb 26, 2002 | 08:46 PM
B16ED4G's Avatar
Default Re: installing axles after dropping b-series motor (Mista B-one-seven)
I just took a hammer and a chiesel, got someone to hold the shaft in place being carful not to dislodge the inner joint and tapped it until it came off, same with the hubs, you shouldn't have to use excessive force, just a few taps
Chris
Old Feb 27, 2002 | 12:11 PM
Giuseppe's Avatar
nice big flat head screw driver.
petr0lb0mb
Transmission & Drivetrain
15
Sep 19, 2018 09:06 PM
Capt. Jimbo McSubipants
Sep 15, 2005 11:26 AM
DC2 to AP2
Jul 6, 2004 11:11 AM
