p72/ p30 redline problem
Old Sep 8, 2005 | 11:53 AM
egricepatrol's Avatar
Default p72/ p30 redline problem
i have a jdm b16a with a 99 head my car seems to redline at 7600 rpms on ym stock p30 but i switched it out for a p72 and it seems to redline at the same. i thought the gsr is at 8000 rpms. could this problem be with my distributor? or my oil pump? any help would be nice
Old Sep 8, 2005 | 12:01 PM
komat's Avatar
Default Re: p72/ p30 redline problem (egricepatrol)
your tach could be wrong
Old Sep 8, 2005 | 12:35 PM
FalkenSiR's Avatar
Default Re: p72/ p30 redline problem (komat)
no codes?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat &raquo;</TD></TR><TR><TD CLASS="quote">your tach could be wrong</TD></TR></TABLE>
Tach has absolutely nothing to do with the way the car behaves.
Old Sep 8, 2005 | 01:23 PM
Relic1's Avatar
P30 - 8200 revlimiter
P72 - 8000 revlimiter
right?
your stock tach could be off that much, either check it with an aftermarket unit or datalogging.
does the engine run out of power at that RPM or stutter?
your head could be installed wrong, could have the wrong cams, could have the gears a tooth off, could be lots of things.
Old Sep 10, 2005 | 11:00 PM
Default Re: (Relic1)
im pretty sure that the tach isnt off cuz my idle is perfect any lower and the car dies. wut u mean bout datalogging?
Old Sep 11, 2005 | 09:14 AM
Relic1's Avatar
Crome/Uberdata setups have a datalogging feature that tells you the exact engine RPM. If you have a stock ECU nevermind.
lexusgui
Jul 27, 2008 07:54 PM
CimorelliCRX
14
Jul 2, 2005 02:25 PM
WhiteGSR95
Mar 29, 2005 08:11 AM
Beezle
Nov 2, 2004 10:33 AM
sit220
Jun 13, 2004 04:07 PM
