1990 HB Sunroof Issue
Just in time for winter, my sunroof is stuck in the open position. When I press the button to close the sunroof, there is no sound coming from the sunroof motor. But when I press the open button, I can hear the motor working. I already checked the switch with a volt-meter and am almost positive that it is functioning properly. I have also tried physically pulling on the sunroof glass while pressing the close button without success.
Has anyone had any similar problems they were able to fix easily? Is there a separate motor for opening and closing the sunroof? Is there an easy way to access the motor(s) to check the status?
Any help would be much appriciated!!
THanks,
-=K
THanks,
-=K
mvp4unc
Apr 17, 2017 08:01 AM
