89+ Suspension
Old Sep 7, 2005 | 11:19 PM
boyer's Avatar
Default 89+ Suspension
my crx si is an 88, what is the difference in the suspension between 88 and 89? im tryin to get a set of KYB AGX's or Tokico Illuminas, but nothing made for 88? what needs to be changed in order to fit those on my car?
Old Sep 7, 2005 | 11:28 PM
Tyson's Avatar
Default Re: 89+ Suspension (boyer)
youll just need 89-91 rear lower control arms. its otherwise the same.
actually, the front brake lines are a bit different, but dont worry, it will still be fine.
if you get the tokicos, itll come with an adaptor bracket to match the 89-91 brake lines, but since you have an 88, you wont need the adaptor. no big deal.
Old Sep 8, 2005 | 04:20 AM
Targa250R's Avatar
be professional
Yep, you'll just need the '89-91 rear lower control arms. That's it.
Old Sep 8, 2005 | 09:07 AM
boyer's Avatar
ok thanks guys will it work with 97 integra rear disc? need 89 lower control arm or integra?
Old Sep 8, 2005 | 09:18 AM
Tyson's Avatar
Default Re: (boyer)
use the 89-91 LCA, dont use the integra arms.
Old Sep 8, 2005 | 10:13 AM
stockbee's Avatar
you're lucky if you wanna do something better than what you mentioned. Tein RA's for an ITR will fit because of the older LCA. the 89-91's would have to use your LCA or the ITR LCA to fit them.
akinas-crx
Oct 6, 2010 11:48 AM
ED9man
21
Jun 7, 2006 05:07 PM
ED9man
Jul 30, 2005 03:09 PM
DB8
Apr 13, 2004 10:44 PM
91hondacrx
Jan 3, 2003 08:38 AM
