LS crank or b20 crank....
Old Sep 7, 2005 | 09:35 PM
JMcDB18C's Avatar
Default LS crank or b20 crank....
I have a 98 Spec R and was wanting to put an LS crank or a B20 crank for a good stroke. Im putting Toda Spec C's and full port and polished head, 82mm pistons 12.0:1 compression, TWM individual throttle bodies. I was wondering if the LS or B20 crank would help with some horsepower and torque since it has a longer stroke??? Any help on this would be appreciated...
Jon
Old Sep 7, 2005 | 09:47 PM
RudeBwaiSi's Avatar
They are one and the same. . .you will gain torque and peak earlier with HP.
Old Sep 7, 2005 | 10:08 PM
JMcDB18C's Avatar
But will I still be able to spin 9000 rpms???
Old Sep 7, 2005 | 10:35 PM
THEUSED's Avatar
You would have to use the LS Rods aswell and their r/s doesnt like 9 at all even if you used ARP rod bolts it would be a stretch, literally, so you have to make a decision power down low or power up high? Personally Id choose the latter since your setup would compliment the revs very well.
Old Sep 8, 2005 | 12:06 AM
fmrprojects's Avatar
they are the same crank and LS vtec dont need to rev past 8500
Old Sep 8, 2005 | 07:53 AM
RudeBwaiSi's Avatar
Default Re: (JMcDB18C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JMcDB18C &raquo;</TD></TR><TR><TD CLASS="quote">But will I still be able to spin 9000 rpms???</TD></TR></TABLE>
With a larger stroke, you don't want to rev that high, unless your motor was FULLY built and is making power that high. Your piston speed would be really fast and will wear out easier, also more chances of cracking a sleeve (if stock). The trade of with more longer stroke is lowend torque for high revving peak hp.
Old Sep 8, 2005 | 10:11 AM
JMcDB18C's Avatar
I see. I am just going to stick with my stock Type R crank then. Thanks guys.
Rice Is Best
13
Sep 2, 2010 02:10 PM
swirve1
Jan 6, 2010 06:23 AM
Da1spaz247
Oct 1, 2005 08:27 PM
jdm92teg
Apr 13, 2005 01:20 PM
