rocker arm removal on 97 lx
Old Sep 7, 2005 | 08:32 PM
accordredliner's Avatar
* B A N N E D *
Default rocker arm removal on 97 lx
I have posted a question on how to remove it and people said that the valves needs to be set or soemthing. Well I looked at my haynes and factory manual and it doesn't say anything about setting the valves. So do I need to set the valves?
Old Sep 7, 2005 | 08:35 PM
deserthonda's Avatar
Default Re: rocker arm removal on 97 lx (accordredliner)
it is best to put car on # 1 top dead center ,then remove rocker arm assembly, when putting together make sure that rocker arms are properly lined up over the valves before you tighten it up or you could bend a valve ..........why are u removing rocker arm assembly???
Old Sep 7, 2005 | 08:37 PM
momstaxi's Avatar
if your replacing or removing the rocker arm assembly you will need adjust the actual valve tappets on the rocker arms when you reinstall...they have the flathead screw driver slot on top surrounded by a 10mm...you will need to follow the instructions and set those to what the valve lash clearance in your manual...
although if your just removing and reinstalling and everyone is in the same location, assuming they were in spec before removal, you would probably be ok, as i have removed plenty of rocker arms and reinstalled w/o clearanceing with no problems, its when you start switching them around you will need to check everyone...
Old Sep 7, 2005 | 08:39 PM
didn,t you have another post on this????? oil in spark plug tubes???why did you start another post???
Old Sep 7, 2005 | 08:41 PM
* B A N N E D *
yeah. I just found my old post. The server was having problem and it didn't show my old post but now I found it.
nightkidracing
Jun 21, 2009 02:21 PM
whereiscarmensandiego
Jul 24, 2008 02:22 PM
turbotime
Nov 16, 2006 08:19 PM
VTECcnIT
Nov 9, 2005 05:43 AM
