FRESH......Fully Built B18C1 with GSR transmission
<U>PRICE REDUCED TO $4600.00</U>
will seperate
OK, this has been my project for awhile now, but due to a family illness, and because I have not found a shell to put it in, I need to sell it.
If you do not like the price.....please keep it to yourself, and if you look at the thread, please bump.
Here is all the information.....
Shortblock
-stock crank (micropolished/oil holes chamfered)
-Eagle rods (ARP rod bolts)
-CP pistons (in this combo, the compression is 13.2:1)
-Golden Eagle sleeved B18C1 block bored to 85mm
-Moroso oil pan
-N1 single groove crank pulley
-Clutch Masters lightweight flywheel
-Type R oil pump
-Honda bearings throughout
Rotating assembly balanced and blueprinted
Shortblock assembled by King Motorsports
Head
-GSR head
-Type R valves
-Crower stage 3 all motor drag cams
-Crower springs, and retainers
-Skunk2 pro series cam gears
-Full race port and polish by King Motorsports
-ARP head studs
-Cometic head gasket
-Toda timing belt
Cams have been degreed (King Motorsports)
Induction
-TWM individual throttle bodies
-port matched to head (King Motorsports)
-N2O fogger kit installed (currently jetted at 150 HP)
-Hondata intake gasket
Ignition
-OBD II distributer
-MSD cap
-MSD rotor
-MSD 6A
-MSD Blaster SS coil
Transmission
-GSR hydro trans
-New bearings
-Richmond spool
-Clutch Masters stage 4 clutch and pressure plate (about 2000 miles on this)
Also included
-complete engine wiring harness
-starter
-alternator w/ underdrive pulley
-Sensors
-brackets
-mounts
The nitrous kit is all new, and includes solonoids, jets, nozzles, brackets, bottle and line.
What you will need: header, injectors, axles, valve cover, and engine management.
$7000.00 OBO possible partial trades considered
ITB pics are prior to port matching
Modified by 2KWK4U at 12:44 AM 9/22/2005
Modified by 2KWK4U at 9:59 PM 9/27/2005
will seperate
Shortblock
-Moroso oil pan
-Type R oil pump
Head
-GSR head
-Type R valves
-ARP head studs
-Toda timing belt
Induction
Ignition
-OBD II distributer
-MSD cap
-MSD rotor
-MSD 6A
Transmission
-GSR hydro trans
-New bearings
-Richmond spool
Also included
-starter
-Sensors
-brackets
-mounts
13.2:1cr+crower3+itbs=crazy
13.2:1cr+crower3+itbs+nitrous=insane!!!!!!!!!!
Modified by KENetics1 at 7:48 PM 9/8/2005
i am not a b series man...but i have to say....i like the set up especially when
nitrious is involved......i was at one time wanting to get rid of my setup,but it seems as tho no one has any money these days.
150 is awful high starting out,but good luck on your sale.
harv
aka
nitrious balla
b20 vtec spraying 400....7.18 @104 spinning almost to the 330 1/8 mile...need
bigger slicks...then she will be in the 6's.
also have a set up if your interested in pm me.
https://honda-tech.com/zerothread?id=1282519
harv
aka
nitrious balla
OK maybe $400
