Fuel Filter question...
i purchased oem honda fuel filter, it came w/ 3 washers: 2 that go on top around banjo fitting, and 3rd one.. the smaller one must go underneath.
while removing old filter i didin't notice that 3rd small washer..
so my question is, does anybody else use the 3rd washer underneath? do i need to use one?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOALA YUMMIES »</TD></TR><TR><TD CLASS="quote">They always come with 3 and I have yet to figure out where the heck the 3rd one goes. </TD></TR></TABLE>
I believe different model integra's share the same fuel filter. The third washer is for the other model integras to use. Not for the R.
x2
But then again, I am completely incompetent and should not be any one's voice of reason.
x2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KayOs »</TD></TR><TR><TD CLASS="quote">I believe different model integra's share the same fuel filter. The third washer is for the other model integras to use. Not for the R.</TD></TR></TABLE>
Bingo.
Bingo.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 »</TD></TR><TR><TD CLASS="quote">one above banjo fitting and bolt, the other one between filter and banjor fitting</TD></TR></TABLE>
Bingo!
Rodney was nice enough to change mine this evening, even though he was busy getting his car ready for national's (thnx Chris).
The 3rd washer is for a different Honda like his Civic that has a breather (pressure releaser) I might have totally miss-explained that, but the DC2 does not need it, he just tossed mine away.
Bingo!
I have tried soaking the bango bolt on the top of the fuel filter with WD40 in my girls '99 EX sedan with 70k. Using a braker bar with socket on the bango bolt and a long wrench to hold upper filter fitting on the filter body. The thing will not budge, hat can I do!!
yes the smaller washer is for the pressure release, you take out the smaller bolt first to release the pressure then take the big one out
, my question is whats that floaty thing do in the clutch fluid resovoir?
Yeah except you're still on your way to being in this years survivor contest happy_guy
2001, notice, ta da its not listed:
Go down to 97, the only one where it lists that stupid bolt where u got that diagram:
It shows it but ah:
027 17765-SM4-000 STAY E, FUEL PIPE 1 1997 Acura INTEGRA 2.28 1.82 Qty:
028 17765-ST7-000 STAY F, FUEL PIPE 1 1997 Acura INTEGRA 3.25 2.60 Qty:
029 90021-P0A-003 BOLT, SEALING (12MM) 1 1997 Acura INTEGRA 6.39 5.11
031 90164-S04-000 SCREW, TAP (6X20) 1 1997 Acura INTEGRA 1.43 1.14 Qty:
032 90301-SP0-003 NUT (6MM) 1 1997 Acura INTEGRA 2.28 1.82 Qty:
Its not listed, you're wrong again, not listed for the ITR.
..2001, notice, ta da its not listed:
It shows it but ah:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOALA YUMMIES »</TD></TR><TR><TD CLASS="quote">Yeah except you're still on your way to being in this years survivor contest happy_guy
..</TD></TR></TABLE>
dont know what that is and idont care either
..</TD></TR></TABLE>dont know what that is and idont care either
if fuel filter is bad, does car start weak? when i turn the key, car start but pretty weak, (slowly picks up and like its gonna die but not) lol
and how much are they from the dealer?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JunkyDC2 »</TD></TR><TR><TD CLASS="quote">if fuel filter is bad, does car start weak? when i turn the key, car start but pretty weak, (slowly picks up and like its gonna die but not) lol
and how much are they from the dealer?</TD></TR></TABLE>
i think under $30, the issue you describe sounds like something other than fuel filter related. maybe something related to fuel evap system, check timing spark plugs/wires and rotor, are you running stock ecu?
