Vibration and noisy engine
Old Sep 7, 2005 | 06:51 PM
FSBxtreme's Avatar
Default Vibration and noisy engine
I have a 1996 Honda Accord LX 101893miles on it. Lately, the engine feels louds and produce grrrr sound at certain rpm. I wonder how I can correct this and make it revs smoother without grrrr noise. Thanks.
Old Sep 7, 2005 | 06:52 PM
HondaAccordTdR's Avatar
Default Re: Vibration and noisy engine (FSBxtreme)
is it around 1800 RPM?
Old Sep 7, 2005 | 07:36 PM
P_Adams's Avatar
Wrap a steel hose clamp around the catalytic converter shield and tighten liberally. They develop broken welds on the top where you can't see them. While you're at it check the rest of the exhaust shields for loose/missing bolts and broken welds also.
P
Old Sep 7, 2005 | 08:09 PM
deserthonda's Avatar
do as P- suggestes... also there is a bulletin on vibration at 1800 rpm ..exh kit comes with new gasket, bolts, springs, the honda dealer might help u with that,,,,,also, have you had timing belt replaced recently ???
theholylancer
Aug 22, 2018 01:41 PM
mrules45
Mar 20, 2012 05:09 PM
colnago
Sep 26, 2006 01:51 PM
vivaladan89
Jun 15, 2006 05:33 PM
2002_SE
Aug 24, 2005 03:35 PM
