are all b series timing belt covers the same
Old Sep 7, 2005 | 06:41 PM
racingant's Avatar
Default are all b series timing belt covers the same
is the timing belt cover off a 91 teg ls with a obd0 ls swap the same as a jdm obd0 b16 swap the same or can i use one from all b series motors
Old Sep 8, 2005 | 03:32 AM
StorminMatt's Avatar
Default Re: are all b series timing belt covers the same (racingant)
Not all timing belt covers are the same. For instance, the LS timing belt covers are meant for a taller block and shorter head (vs B16A timing belt covers). In other words, LS timing belt covers will not work on a B16A.
Old Sep 8, 2005 | 04:21 AM
teler86's Avatar
bump cus im interested too
Old Sep 8, 2005 | 07:54 AM
UsDm_Junky's Avatar
what would be the ideal timing belt cover considering you are running an ls/vtec settup?
Old Sep 8, 2005 | 08:04 AM
drdisco69's Avatar
And the OBD2 covers have the place for the crank fluctuation sensor.
Old Sep 9, 2005 | 04:54 AM
racingant's Avatar
so i can only use a b16 timing belt cover for my jdm obd0 b16 are all the b16 ones the same or do i have to get one from a jdm b16 swap
Team AnWuT
Mar 23, 2006 12:27 PM
racingant
Dec 17, 2005 04:23 PM
AVATAR
Apr 6, 2005 04:10 AM
drewlee
Mar 6, 2004 05:24 AM
