Stripped bolt......CRX......on shock tower help!!!!!
Old Sep 7, 2005 | 06:40 PM
b18_crx's Avatar
Default Stripped bolt......CRX......on shock tower help!!!!!
ok today is my day off and i woke up kinda early to try and put these one my crx!
tokico illuminas
with sportline springs
i was excited and anxious to install them when it happened. I had all bolts out except for the shock tower ones. i went for the first one and lwent for the breaker bar. snap it broke loose no problem. After that it was on for the second one went for the breaker/cheater bar and nothing happened. Tried again and i i realized that the bar moved but the nut didnt........dammit
this is what the damage was!
now my first instinct was to go get some vise grips and take it out but i just wanted to post up to get people opinions and how you guys have dealt with stripped bolts/nuts in your ef....
Modified by b18_crx at 9:36 PM 9/7/2005
Old Sep 7, 2005 | 06:46 PM
JDM Panda's Avatar
Default Re: Stripped bolt......CRX......on shock tower help!!!!! (b18_crx)
Try the vice grips. Thats the only thing i can think of
Old Sep 7, 2005 | 06:48 PM
ClimaxCRX's Avatar
Sears there are special sockets made by craftsman that remove stripped nuts and bolts. I think they cost like $20 or $30 bucks and you get a whole set. That is what I did when I had a stripped nut on my header.
Old Sep 7, 2005 | 06:50 PM
b18_crx's Avatar
Default Re: Stripped bolt......CRX......on shock tower help!!!!! (JDM Panda)
some on here also told me to just get a 1mm smaller socket i dont care about and hammer it on...what do yall think!?
Modified by b18_crx at 9:06 PM 9/7/2005
speedd2286's Avatar
Default Re: Stripped bolt......CRX......on shock tower help!!!!! (ClimaxCRX)
or could use a 1mm smaller socket and hamemer it on
Old Sep 7, 2005 | 06:53 PM
sam385's Avatar
Default Re: Stripped bolt......CRX......on shock tower help!!!!! (speedd2286)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM Panda &raquo;</TD></TR><TR><TD CLASS="quote">Try the vice grips. Thats the only thing i can think of </TD></TR></TABLE>
if it's stripped use the grip.
of course, you will be replacing the nut and bolt
Old Sep 7, 2005 | 07:09 PM
Contender25
Guest
Posts: n/a
TAKE you'r hammer and put a 1mm smaller like those guys were talking about on it, and pound it on with the hammer till it's stuck, i have done this before. Anyways then you break it lose, when you get it off throw the socket with the nut stuck in it on the concrete a couple times to jar it loose from the socket, but make SURE you'r eyeball keeps track off that socket so it doesn't fly into the woods.
Old Sep 7, 2005 | 07:10 PM
speedd2286's Avatar
Default Re: (Contender25)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Contender25 &raquo;</TD></TR><TR><TD CLASS="quote">TAKE you'r hammer and put a 1mm smaller like those guys were talking about on it, and pound it on with the hammer till it's stuck, i have done this before. Anyways then you break it lose, when you get it off throw the socket with the nut stuck in it on the concrete a couple times to jar it loose from the socket, but make you you'r eyeball keeps track off that socket so it doesn't fly into the woods. </TD></TR></TABLE>
Old Sep 7, 2005 | 07:11 PM
Contender25
Guest
Posts: n/a
Btw if the 1mm smaller doesn't seem to still go on, just check a few differen't other size sockets for it and see which one would fit/get pounded on they're the best. EDIT: Thanks for the thumbs up, but this isn't that hard, lol...
Old Sep 7, 2005 | 07:30 PM
teler86's Avatar
i always go with standard sockets if i strip out a metric one
Old Sep 7, 2005 | 08:07 PM
b18_crx's Avatar
Default Re: (teler86)
i did try to put 1mm socket and i think its a 14mm but i tried 13 mm no luck!
Old Sep 7, 2005 | 08:17 PM
TurtleEF3's Avatar
Default Re: (b18_crx)
I had the exact same problem with my shock tower in the rear. I tried vise grips and a smaller size socket but they didn't work. I had to cut the nut off with a dremel.
Old Sep 7, 2005 | 08:23 PM
shawn_crx's Avatar
Default Re: (EFcivicHB)
vise grip.....
If you need those bolts. I think I have couple laying around in the garge.
Or just go to hardware store and buy you one.
Old Sep 7, 2005 | 08:35 PM
b18_crx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFcivicHB &raquo;</TD></TR><TR><TD CLASS="quote">I had the exact same problem with my shock tower in the rear. I tried vise grips and a smaller size socket but they didn't work. I had to cut the nut off with a dremel. </TD></TR></TABLE>
whats a dremel?
Old Sep 7, 2005 | 08:37 PM
b18_crx's Avatar
[QUOTE=b18_crx]some on here also told me to just get a 1mm smaller socket i dont care about and hammer it on...what do yall think!?
tried that didnt work for me!
Old Sep 7, 2005 | 09:16 PM
Ch3mik's Avatar
ihave a dremel tool. did you try a standard socket? did u spray it with some wd 40? then try the smaller socket?
Old Sep 7, 2005 | 10:23 PM
tyro's Avatar
Default Re: Stripped bolt......CRX......on shock tower help!!!!! (Ch3mik)
Get out the vice grips and go to town. Worst that could happen is you'd be buying a new strut mount - $15.
Get some six-point sockets, twelve point just rounds everything off.
And yes, those nuts require a 14mm socket.
Old Sep 7, 2005 | 10:28 PM
be8teensee1's Avatar
heat that sh*t up and vise grip it
Old Sep 7, 2005 | 11:41 PM
ComputerJLT's Avatar
i've always used a grinder and bypassed the bitch nut
Old Sep 8, 2005 | 12:23 AM
Tyson's Avatar
here's a tip, make sure you put the nut on the other side of the top hat and tighten that down good. it will help relieve some of the friction holding that stripped nut in, and whatever method you try to screw it out much easier. i would even try to push the shock in the direction of the stripped nut to make the nut even looser, if you understand what im getting at.
anyway, good luck. vice grip seems like your best option, but its gonna be hard to clear the way to get a good grip on it.
oh yeah, and learn from your mistake, if youre ever in a situation where you need a breaker bar, make sure its a 6 point socket, not 12. if you were using a 6 pt socket when this happened, then you must not be using good tools. invest in good tools.
Old Sep 8, 2005 | 07:32 AM
b18_crx's Avatar
Default Re: Stripped bolt......CRX......on shock tower help!!!!! (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">here's a tip, make sure you put the nut on the other side of the top hat and tighten that down good. it will help relieve some of the friction holding that stripped nut in, and whatever method you try to screw it out much easier. i would even try to push the shock in the direction of the stripped nut to make the nut even looser, if you understand what im getting at.
i was using craftsman professional.........i think, craftsman for sure! ok let see what happens after work today will update after work!
Old Sep 8, 2005 | 08:59 AM
lodo1's Avatar
get the craftsman easy out set. 50 bucks, but its the best 50 bucks you could possibly spend.
Old Sep 8, 2005 | 09:06 AM
Tyson's Avatar
Default Re: Stripped bolt......CRX......on shock tower help!!!!! (tdocrx)
easy out is not going to help this situation....
Old Sep 8, 2005 | 09:12 AM
b18_crx's Avatar
SO VISE grips then? or smaller socket?
Old Sep 8, 2005 | 09:18 AM
Tyson's Avatar
go ahead and try a 13mm 6pt socket or box end wrench first. and then try vice grips.
