head question
Old Sep 7, 2005 | 04:56 PM
96accordLX200004's Avatar
Default PLEASE HELP swaping heads on the f22 PLEASE HELP
I have a 96 honda accord lx with the f22b2 motor and i was wonder if the f22a1 (older accord) head would fit onto the block of the f22b2. i have a friend with one and he is willing to sell it for dirt cheap so i wondering if it would fit.
Thanks
Modified by 96accordLX200004 at 7:33 PM 9/7/2005
Old Sep 7, 2005 | 06:49 PM
gianinline's Avatar
The "B" means: second generation engine, and the "A"..means... first generation engine...
You should go do a little research, to see if all screws, and gasket fit properly, if no one give you the answer.
Old Sep 7, 2005 | 06:54 PM
gianinline's Avatar
I was looking at that right now... and... looks like it will not fit.
The F22A is a non-vtec SOHC... and F22B is a Vtec SOHC... looks like the F22B head is bigger than the "A" one!
Old Sep 7, 2005 | 08:34 PM
LOGICx420x's Avatar
Default Re: PLEASE HELP swaping heads on the f22 PLEASE HELP (96accordLX200004)
The F22B is longer, like a long block I guess you can say!!
Old Sep 7, 2005 | 08:41 PM
momstaxi's Avatar
Default Re: PLEASE HELP swaping heads on the f22 PLEASE HELP (LOGICx420x)
first, if you have a f22b2 your motor is not vtec....regardless all those heads will interchange just fine, vtec or not - an f22a head will fit perfectly on an f22b1,2 block just fine..all the headgaskets are the same part #.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LOGICx420x &raquo;</TD></TR><TR><TD CLASS="quote">The F22B is longer, like a long block I guess you can say!!</TD></TR></TABLE>
they are the same size...
Old Sep 8, 2005 | 11:22 AM
thanks this helps a lot
LawlessOne
Sep 19, 2014 06:12 AM
ronqqq
Nov 3, 2006 05:18 AM
1991HondaAccord
Nov 25, 2004 05:45 PM
Soundwave9900
Oct 25, 2002 09:27 AM
