Crank Girdle Torque Specs
By "girdle" I assume you mean bearing cap bridge, in which case the torque spec is 45 N-m or 33 lb-ft.
The manual also states: apply engine oil to the bolt threads and washers. After torquing each cap, turn the crank to check for binding.
Helms manuals are worth buying, this one cost $60 and it has already paid for itself.
