Who can make a custom distributor cap?
Old Sep 7, 2005 | 02:05 PM
Andre's Avatar
Default Who can make a custom distributor cap?
I've converted to individual coils (Ultra MDI) today...
... and the distributor is now except the sensors useless. I would like to have a flat (carbon) cap without the terminals. Who could make one?
Old Sep 7, 2005 | 03:06 PM
LSEGHATCH's Avatar
Default Re: Who can make a custom distributor cap? (Andre)
I'd like to see this when its done....
Old Sep 7, 2005 | 05:05 PM
blueoval557's Avatar
Default Re: Who can make a custom distributor cap? (LSEGHATCH)
Me too. I gotta compliment you on the engine bay. It looks awesome! I love the plain aluminum valve cover. Is it a Moroso?
Kyle
Old Sep 7, 2005 | 05:31 PM
evil_s13's Avatar
well it says moroso on it if you look in the first pic
Old Sep 7, 2005 | 09:58 PM
b18ccivics's Avatar
Default Re: (evil_s13)
i could not get anybody to make me one out of aluminum so i had to make one myself. And i have about 80 thousand hours in it so i will not make another one. If you find somebody to make one out of carbon or what ever, pm me i am interested in buying one.
Old Sep 8, 2005 | 05:12 AM
BoostedEG6's Avatar
Default Re: (b18ccivics)
why not just use a cam cap? I think that would probably be your best bet
Old Sep 8, 2005 | 05:52 AM
Andre's Avatar
Default Re: (BoostedEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedEG6 &raquo;</TD></TR><TR><TD CLASS="quote">why not just use a cam cap? I think that would probably be your best bet</TD></TR></TABLE>
"....except the sensors..."
Old Sep 8, 2005 | 05:54 AM
BoostedEG6's Avatar
Default Re: (Andre)
yeah I didnt think about that..... hahahaha
Old Sep 8, 2005 | 07:31 AM
k24em2's Avatar
Pick up one of the cam angle sensors from tony1 and use that on the cam gear if you are running a full stand alone.
Old Sep 8, 2005 | 07:43 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: (k24em2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k24em2 &raquo;</TD></TR><TR><TD CLASS="quote">Pick up one of the cam angle sensors from tony1 and use that on the cam gear if you are running a full stand alone.</TD></TR></TABLE>
Old Sep 8, 2005 | 08:32 AM
Andre's Avatar
The Power FC requires the stock cam and crankshaft sensor and the Ultra MDI plugs between the engine harness and distributor.
Old Sep 8, 2005 | 01:34 PM
cubish's Avatar
Default Re: (Andre)
Old Sep 10, 2005 | 09:58 AM
NJcoupe's Avatar
I know its some what off-topic, But can you use MSD dis-4 with the MSD blaster coils or like OEM RSX/d17 coil packs using the internals from a stock dizzy with an OEM honda ecu?
Old Sep 10, 2005 | 01:25 PM
siblues's Avatar
Default Re: (RHDej2.)
As far as I have researched the 2000 and earlier honda ecu's only have one coil driver so I dont think its possible but I dont know about the newer ecus.
Old Sep 10, 2005 | 01:39 PM
NJcoupe's Avatar
I understand that, but the 1 coil driver would send that signal to the MSD DIS-4 box which intern would send out the 4 signals to the other 4 coils.
Old Sep 10, 2005 | 02:43 PM
wantboost's Avatar
Who is Mr Robot?
i guess you could do that with a wasted spark setup
Old Sep 10, 2005 | 02:48 PM
snowseeker's Avatar
Default Re: (wantboost)
I was going to run a DSM cam angle sensor on my motor in place of the disty.
Old Sep 10, 2005 | 08:48 PM
RC000E's Avatar
Default Re: (snowseeker)
If I knew it was worth my time, I could certainly make some carbon fiber caps. I didn't know that many people were running individual coil setups which is why I decided not to make them originally.
Old Sep 11, 2005 | 03:26 AM
Andre's Avatar
Default Re: (RC000E)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RC000E &raquo;</TD></TR><TR><TD CLASS="quote">If I knew it was worth my time, I could certainly make some carbon fiber caps. I didn't know that many people were running individual coil setups which is why I decided not to make them originally. </TD></TR></TABLE>
I guess you could sell at least 10 for about $50. You could get stock caps and cut off the terminals and then put on 1 layer of carbon.
Old Sep 11, 2005 | 10:03 AM
RC000E's Avatar
Default Re: (Andre)
Yeah, that would be one option, but overlay tends to be more labor intensive than simply molding.
I will put together a mockup and if anyone is still interested then I will make a few.
Old Sep 14, 2005 | 12:56 AM
94ta_lt1's Avatar
overlaying takes no time at all...I've done alot of overlaying for parts and i have also reverse molded my entire interior and made it out of cf. I would think the overlaying it would be the way to go...I can do a few if anyone wants them done...just pm me. My name is 69vette over at ls1tech.com. I'm not really all about hondas but i enjoy reading this forum and would be willing to help anyone out that needs it. Just let me know
Modified by 94ta_lt1 at 2:25 AM 9/15/2005
Old Sep 14, 2005 | 04:42 AM
john breezy's Avatar
Default Re: (94ta_lt1)
looking good
Old Sep 14, 2005 | 12:13 PM
efficiencyJunkie's Avatar
Default Re: (john breezy)
Whats the advantage of the individual coil setup?
Old Sep 14, 2005 | 10:01 PM
RC000E's Avatar
Default Re: (carbnjunkie)
Sorry I haven't been back yet people. I got this b*tch and her dad riding my *** to finish her Civic. I'm doing my best, but this is a CVT car and I am getting into some small mounting issues which have caused delay.
I'll be here when I get 1 or two of these done.
Carbjunkie...there are quite a few advantages to individual coils. Increased spark output to eliminate misfire in high cylinder pressures is one reason. Also, for high revving engines, a rotor can lead to sparks jumping the gap and causing pre-ignition and things like that. The coils eliminate that problem.
Old Sep 15, 2005 | 01:26 AM
94ta_lt1's Avatar
what cap are the stock ones that you are starting with? just ant b series?
