Intermittent Starting and Cut Out
Old Sep 7, 2005 | 12:46 PM
myfirstthonda's Avatar
Default Intermittent Starting and Cut Out
We purchased a 98 Accord about 6 months ago and after 3 months it began to intermittently not start. It cranked but didn't turn over. On sevreral occasions it even cut out while driving and would not restart. Usually after only a few minutes it will start. It does not seem to be an only when its hot phenomena. I replaced the ignitiion coil and the problem is still there. No one can seem to get this to happen when it is in the shop. Any other experiences like this or suggestions for troubleshooting? Thanks
Old Sep 7, 2005 | 08:32 PM
deserthonda's Avatar
Default Re: Intermittent Starting and Cut Out (myfirstthonda)
when it happens on you , u need to see if it is fuel or spark related,,,,,,,carry a can of carb cleaner, when car does not start, remove the intake tube going to throttle body and spray some carb cleaner in there , if car starts it is fuel related,,,,,,,a bad main relay ?? fuel pump??,,,,,,,,,i would chk the relay first
Rollin' South
Jul 23, 2018 01:50 AM
K'netic
Jul 3, 2015 07:37 AM
LSteggyguy
Aug 18, 2014 08:12 AM
1604169
Nov 17, 2012 07:52 AM
White98LS
Jul 14, 2007 07:46 AM
