Suspension & Brakes Theory, alignment, spring rates....
trailing arm bolts
Old Sep 7, 2005 | 08:21 AM
DC4_MADMAN's Avatar
Default trailing arm bolts
I will be reaplacing my current drum TAs with TAs from a teg for rear disc.
Car is originally from Minnesota and yes I had 3 bolts seize when I replaced my rear LCAs.
Question is will I have to worry about similar issues with the TA bolts that connect the TAs to the body?
Thanks.
Old Sep 7, 2005 | 09:08 AM
Relic1's Avatar
I haven't had any problems with the few that I've taken off. But they are tight.
also coating the bolts with anti-seize will help from having the seized bolt problem again. (coat the inside of the bushing and threads of the bolt)
Old Sep 7, 2005 | 09:22 AM
DC4_MADMAN's Avatar
Default Re: (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">I haven't had any problems with the few that I've taken off. But they are tight.
also coating the bolts with anti-seize will help from having the seized bolt problem again. (coat the inside of the bushing and threads of the bolt)</TD></TR></TABLE>
Car is in cali now, so I am not too concerned with the new bolts seizing again.
I have an impact gun so the TA bolts shouldnt give me too much trouble, I just didnt want to deal with trying to get a busted bolt out of the body.
HotCheetos
10
Dec 11, 2010 09:07 PM
cheapskate
Suspension & Brakes
Apr 22, 2008 12:50 AM
usmarinedelta
Dec 27, 2006 08:52 PM
ZipTieGUy
Feb 27, 2006 06:08 PM
Soda Popinski
Mar 30, 2004 05:18 PM
