D15 block same as D16 block?
I've searched some, but also need a quick answer. I shot a rod in my 90 CRX si D16a6 block this past weekend. I can get a good D15 block real cheap. Just wondering what are the differences with the block? No issues with putting the D16a6 head and intake on either right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exsinnovation »</TD></TR><TR><TD CLASS="quote">which is taller the d16?</TD></TR></TABLE>
yep. 3mm taller.
yep. 3mm taller.
but to answer your question, It will work as a replacement, The blocks are almost the same a few more differences than listed above but, The A6 and D15 heads are identical, the difference being the cam & cam gear.
as for the block itself, The Main journals are smaller, so it will not accept a D16 crank.
But the Rods are the same.
