D15B JDM 130HP tech/spec?
Old Feb 26, 2002 | 04:00 PM
Zeus Zore's Avatar
Default D15B JDM 130HP tech/spec?
any spec as..: valve clearens/adjusting
timingbelt?? witch could be used !!?
and so on !!! PLZ !!!
maybe links !?!?
hobe you guys can help my !!
Old Feb 26, 2002 | 05:14 PM
rainforest's Avatar
Default Re: D15B JDM 130HP tech/spec? (Zeus Zore)
try teh d-series board i know its the same size head as the other d-series heads so the iming belt would prolly be the d15y7. but man i want to see a 3stage vtec mini me
Old Feb 26, 2002 | 05:43 PM
Zeus Zore's Avatar
Default Re: D15B JDM 130HP tech/spec? (rainforest)
WHERE ???? what board ?? ?? plz !!
thx
but it is not the 3 stege vtec !! it is the on like D16Z6 but "only" 1,5 with vtec
plz help me
thx agian
Old Feb 26, 2002 | 07:57 PM
fixhondas's Avatar
I would say valve specs are 0.20 mm intake and 0.25 mm exhaust under 100 degrees F.
Belt is probably the same as a 92-95 civic Vx.
Old Feb 26, 2002 | 09:20 PM
Zeus Zore's Avatar
Default Re: D15B JDM 130HP tech/spec? (fixhondas)
thx !!
what engine does the VX have ??? im from denmark, so the letters does dont match !! but the engine codes those as... EX = D16Z6 = ESI in denmark etc.
[Modified by Zeus Zore, 6:21 AM 2/27/2002]
Old Feb 27, 2002 | 11:39 AM
fixhondas's Avatar
D15Z- lean burn VTEC-E economy engine- has longer rods then non-vtec D15
Old Feb 27, 2002 | 02:07 PM
Zeus Zore's Avatar
ok i see ( i know that model
so you think the timing belt would fit from the D15Z1 ????
whyS0serious
Jun 18, 2016 09:49 AM
94civiccpe
10
Mar 27, 2013 05:03 PM
gearhead16
Feb 24, 2010 08:20 AM
Dymond
Jan 8, 2009 08:38 PM
Slimm-rw-
16
Nov 18, 2005 03:55 PM
