Throttle body sticking on 6th gen
Old Sep 6, 2005 | 07:33 PM
cybercrx00
Guest
Posts: n/a
Default Throttle body sticking on 6th gen
Just curious if anyone has has this problem on the 4 cylinder. when you first touch the throttle it stick so you have to push it a bit hard and it moves, gut only sticks at the top. I checked the cable it is good and it seems that it is sticking at the throttle body. I sprayed the outside down with WD-40 to see if maybe something was dirty but it still sticks. Just curious before I start taking it off if there is something I should look for.
Old Sep 6, 2005 | 08:00 PM
philadd's Avatar
Default Re: Throttle body sticking on 6th gen (cybercrx00)
I had the same problem before. Cleaned out the inside of throttle body and problem solved. Probably took me all of 10 minutes, including the removal and reinstallation of the intake.
Old Sep 6, 2005 | 08:06 PM
Crono139's Avatar
Get some TB cleaner, and spray some directly into your throttle body. There will be directions on the can, of course.
Old Sep 6, 2005 | 08:09 PM
tyro's Avatar
Default Re: Throttle body sticking on 6th gen (philadd)
Yes, throttle body cleaner, toothbrush and a little time.
You shouldn't need much cleaner to complete the job.
Old Sep 6, 2005 | 09:05 PM
Crono139's Avatar
Almost forgot.
Don't use the little straw that comes with the TB cleaner. You definitely don't want it in your motor.
Randysi
Aug 14, 2011 05:18 PM
todaV-TecEF8
Mar 24, 2009 01:53 PM
Cpt Ben
Apr 5, 2007 07:18 PM
monkalotamus
Nov 15, 2006 06:31 PM
FATninja19
Jun 26, 2006 10:51 PM
