ek d16 into a ef?
Old Sep 6, 2005 | 07:30 PM
aak's Avatar
aak
Default ek d16 into a ef?
i have a ef beater, and an ek which i plan doing a swap with. the d16 in the ek runs flawlessly, to the point were i hate to get rid of it. the question is do i go through to *** ache of putting the d16 in the ef, or sell the whole set up out of the ek, and buy a used motor for the ef. i'm not concerned about power, moreso reliability in the ef. if someone has pro/cons that would make this decision easier, it will be appreciated! thanks
Old Sep 6, 2005 | 08:19 PM
vtecn8ive's Avatar
Default Re: ek d16 into a ef? (aak)
Yes it'll work. Pretty much drop in. What type of CRX/Civic do you have? SI, DX, HF, Ex??
Old Sep 6, 2005 | 08:47 PM
aak's Avatar
aak
Default Re: ek d16 into a ef? (vtecn8ive)
it's a 90 4dr lx
Old Sep 8, 2005 | 03:37 AM
StorminMatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aak &raquo;</TD></TR><TR><TD CLASS="quote">it's a 90 4dr lx</TD></TR></TABLE>
It will drop in. Remember that this motor is basically the same thing as the A6. And as such, it is a drop in swap, provided you use your ED driver's side bracket and mount. You might also (but not necessarily) need to use your ED clutch and flywheel. Besides that, it is entirely possible to use your DPFI to run this motor. But upgrading to MPFI, using the 1988-1991 A6 ECU, intake manifold, distributer, etc., would be a MUCH better choice.
Old Sep 8, 2005 | 05:00 AM
vtecn8ive's Avatar
Default Re: ek d16 into a ef? (StorminMatt)
^^ that is correct ^^
What kind of d16 is it? vtec or nonvtec?
Old Sep 8, 2005 | 08:42 AM
turboEFboy's Avatar
It will work. I have the D16Y7 in my work beater, which is a 90 hatch si. Best would be to convert from the DPFI though. Either way.
Old Sep 8, 2005 | 06:23 PM
aak's Avatar
aak
Default Re: ek d16 into a ef? (turboEFboy)
it's a non vtec d16. what wiring complications are involved? electrical **** hurts my head. what's the easiest way to make this happen? how do you go from obd0 to obd2? thanks for the info so far, you guys are a big help!
Old Sep 8, 2005 | 07:52 PM
juice91si's Avatar
you will keep the car obd0
Rhonda14
Suspension & Brakes
Apr 5, 2011 11:11 AM
B16EJ
Mar 19, 2005 01:34 PM
eg360B
May 26, 2004 04:20 PM
McD
Jan 30, 2003 01:43 PM
