All Motor Gsr Hatchy ?
Old Sep 6, 2005 | 07:27 PM
Drizzo's Avatar
Default All Motor Gsr Hatchy ?
I have a hatchy with a gsr setup in it . Basically stock compression with type r cams , intake, exhaust , headers . Im about to put on a skunk 2 im and i was woudnering if i should put a 68mm skunk 2 thorttle body or this 62mm type r throttle body i have laying around . Im not going all out so i was wounderin if that 68mm is over assesive ? what are your thoughts , i know from past exp. bigger aight always better .
Old Sep 6, 2005 | 07:36 PM
FROSTDC2's Avatar
Default Re: All Motor Gsr Hatchy ? (Drizzo)
ull have to get a throttle cable relocator and R cable for itr tb, id get the skunk throttlebody if u could, do u have stock springs and retainers? u should look into cam gears and ecu and tune the cams a bit
Old Sep 6, 2005 | 07:42 PM
blaster834's Avatar
Yup go as big as you can
Old Sep 6, 2005 | 07:44 PM
Yambor's Avatar
Default Re: (blaster834)
68mm is a tad overkill for your setup..
send your stock tb out to get it bored..
Old Sep 7, 2005 | 07:56 AM
JDMSiGuy17's Avatar
Default Re: (JH4DC4-2GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JH4DC4-2GSR &raquo;</TD></TR><TR><TD CLASS="quote">
yeah i wouold send it out to maxbore and for $100 i think he will bore it out to 64 or 65 and that should be good for your setup!
Old Sep 7, 2005 | 08:18 AM
Viorent Grip! EG's Avatar
i love the itr tb....
i've had a hand full of aftermarket ones...and i hate how alot of these has sticky plates...
eom itr tb has never given me any problems...
if u want bigger...send it out...but i'm breaking 200whp with itr tb
94xGSRxINTEGRA
May 31, 2007 11:17 AM
digital sol
Jun 27, 2006 10:33 AM
hlee5363
Nov 8, 2005 07:13 PM
stevieteg
Feb 25, 2005 10:56 AM
whtgsr1998
Mar 6, 2002 06:11 PM
