91 honda accord "S" light on and battery drain
Old Sep 6, 2005 | 07:12 PM
madsnave's Avatar
Default 91 honda accord "S" light on and battery drain
Hi there,
My wifes accord has been going down hill this last week. It started with her S light staying on (already replaced the speed sensor when it was blinking) and it stopped shifting. I was able to fix it by unplugging one termanal of the battery but now that doesn't even fix it. It also drains the battery within about 12-14 hrs. Is there any thing i can do to fix this or will i need a whole new AT computer? Also her driver side automatic seat belt stopped working and constantly beeped at her untill i removed the fuse when it was in the up possition. will i need a new motor for that? Thank you for your time and help!
Old Sep 20, 2005 | 01:48 PM
madsnave's Avatar
Default Re: 91 honda accord "S" light on and battery drain (madsnave)
any suggestions?
Old Sep 20, 2005 | 02:42 PM
ap716's Avatar
sorry but what is this s light?
Old Sep 20, 2005 | 03:08 PM
NAiL05's Avatar
Default Re: (ap716)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ap716 &raquo;</TD></TR><TR><TD CLASS="quote">sorry but what is this s light?</TD></TR></TABLE>
Its a sport mode for AT accords. When you mean not shifting is it staying in a taller gear? or is it just not moving at all. Have you also tried jumping the codes off of the TCM aka tranny computer??
Old Sep 20, 2005 | 07:16 PM
madsnave's Avatar
Default Re: (NAiL05)
Yes it's staying in 2nd gear. I know this cause i can maunally shift to 1st second but in d3 and d4 it just stays in 2n'd. I haven't taken the trany code i'll take it in and see what it comes out as.
Old Sep 22, 2005 | 07:03 PM
vedha's Avatar
Default S light
what is TCM aka tranny computer
Old Sep 22, 2005 | 07:40 PM
glamXXXrock's Avatar
i thought it was the TCU???
Old Sep 22, 2005 | 08:06 PM
BLKFLSH's Avatar
Default Re: (madsnave)
It's called many different names. The computer that controls the transmission. You should be able to jump the sevice check connector (in 92 molels it's a plug behind the passenger side kickpanel with two wires that is not connected to anything) You just connect (jump) the two wires together (paperclip works great) by making a U out of it and pushing it into the plug. Then when you turn the key on it will blink a problem code using the D4 light in the dash. long flashes and short flashes, three long flashes and four short flashes would be code 34. If you have a repair manual you could look up the codes yourself and clear the codes, if nessessary.
No scan tool needed.
Old Sep 22, 2005 | 08:57 PM
ricebike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by madsnave &raquo;</TD></TR><TR><TD CLASS="quote"> Also her driver side automatic seat belt stopped working and constantly beeped at her untill i removed the fuse when it was in the up possition. will i need a new motor for that? </TD></TR></TABLE>
I know that my local honda dealer would cover this repair for free... it has a limited lifetime warranty on those as long as u own the car... i dunno how close is a honda dealership to u, though... call or email them to verify...
Old Sep 22, 2005 | 09:41 PM
NAiL05's Avatar
TCM - tranny control module same thing different name. But anyway jump the codes with a paperclip as mentioned above. But kinda sounds like your shift solenoid to me but jump them and see what it says.
Laura_lee48
Apr 8, 2011 07:38 AM
BauerHaus
Jun 28, 2006 12:07 PM
