how to id b series transmissions
Old Sep 6, 2005 | 06:58 PM
flatty's Avatar
Default how to id b series transmissions
can anyone tell me how to tell the differents between the different b series transmissions (ls/gsr/type r/ si) exc please help trying to not get scamed
Old Sep 6, 2005 | 07:00 PM
duggy's Avatar
The stamps on the tranny. You can't tell between LS and GSR though. Only way is to run the VIN (if there is one) or drive it.
Old Sep 6, 2005 | 07:02 PM
95DxSi-R2
Guest
Posts: n/a
Default Re: how to id b series transmissions (dundulk si)
well what tranny are u trying to get?
Old Sep 6, 2005 | 07:12 PM
flatty's Avatar
Default Re: how to id b series transmissions (95DxSi-R2)
ok my friend said he has a type r that needs rebuilt but how can i tell it is a type r
Old Sep 6, 2005 | 07:23 PM
95DxSi-R2
Guest
Posts: n/a
it should say s80 on the tranny with a bar code sticker on it. jdm or usdm?
Old Sep 6, 2005 | 07:28 PM
flatty's Avatar
is that the only way to tell?
Old Sep 6, 2005 | 07:31 PM
95DxSi-R2
Guest
Posts: n/a
don't know
Old Sep 6, 2005 | 07:44 PM
hatchi's Avatar
look through where the axle goes in. if you can see straight through then it has lsd hence itr unless he has gsr and put in lsd. If there is metal blocking it then its most likely not itr
Old Sep 6, 2005 | 07:48 PM
1slowhatchie's Avatar
Default Re: how to id b series transmissions (hatchi)
http://www.ff-squad.com/tech/temp/Bgears.htm
this might help
Pacmane
Transmission & Drivetrain
Feb 16, 2015 09:36 AM
i_am_a_black_man
Mar 17, 2008 05:55 PM
matto2413
Jun 25, 2006 10:29 PM
slthatch
Apr 21, 2005 11:38 AM
bottlefedb18c1
Aug 18, 2003 02:24 PM
