Annoying sound coming from front suspension....
Old Sep 6, 2005 | 06:31 PM
Mark D. Surface's Avatar
Default Annoying sound coming from front suspension....
The car is a 94 CX H/B with about 88,000 miles. I just finished installing a set of Omnipower coilover sleeves. The front is set @ about "1.5 and the back is set @ "1 lower than stock. I'm using the stock shocks/strut since I'm not going that low. Now I read the archived post
https://honda-tech.com/zerothread?id=1078663
on installing these things about a million times. With all said and done the front makes a funny noise when the suspension is compressed. Did I lower it too much past the capabilities of the struts? Could it be the front sway bar making this noise? Is something too tight or not tight enough? No power tools where used on the install so I'm assuming that it's not " too tight ". Anybody else ever encountered this noise when installing coilover sleeves? Skunk2, GC's, Omni's? I can't put my finger on it so I turn to the help of you guys.
Thanks in advance!
vamshi
Suspension & Brakes
May 8, 2018 08:51 AM
jorge59la
Dec 1, 2010 12:01 AM
jayare05
Mar 22, 2009 11:24 AM
arcboy
Jan 10, 2007 03:19 PM
