I have my code but my Pilot radio won't ask for it.
Old Sep 6, 2005 | 03:41 PM
deadpilotradio's Avatar
Default I have my code but my Pilot radio won't ask for it.
I have a 2003 Pilot. I ran down the battery using a cigarette lighter tire compressor. I didn't even run it down to the point that the car wouldn't start, but now my radio is dead. The anti-theft light flashes, but the display is blank. I have disconnected the battery, but I still do not get a prompt for the Code. I know the code, it just won't ask for it. Can any help with this one?
Thanks.
Old Sep 6, 2005 | 05:02 PM
romoracing's Avatar
Default Re: I have my code but my Pilot radio won't ask for it. (deadpilotradio)
If the screen is just blank. Then just press the volume button and see what happens.
Old Sep 7, 2005 | 06:28 AM
Default Re: I have my code but my Pilot radio won't ask for it. (romoracing)
Nothing happens when I push any button---volume (power), AM, FM, CD or TAPE. I forgot to mention that it is an EX model, but no DVD or Navigation system. Is there a fuse or fusible link in the radio itself?
Old Sep 7, 2005 | 08:11 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deadpilotradio &raquo;</TD></TR><TR><TD CLASS="quote">Nothing happens when I push any button---volume (power), AM, FM, CD or TAPE. I forgot to mention that it is an EX model, but no DVD or Navigation system. Is there a fuse or fusible link in the radio itself?</TD></TR></TABLE> There will be 2 fuses, not sure on a Pilot but on most Honda/Acuras the acc., [switched power] fuse is in the in car fuse box and the constant, [unswitch, power all the time] fuse is in the engine bay fuse box, [normaly a 7.5A]
If nothing is coming on on the HU it has to be the acc. fuse, or there is something wrong with the HU, as the red flashing light is powered by the constant power, I don't know of any oem HU that have a fuse or fusible link on the unit itself, but you may have to pull the HU to find out if the other fuses are good, BTW just because the fuse "looks" good does not mean it is, to be sure, replace it with a new one.
If you have to remove it try here for help.. http://www.installdr.com/ 94
Old Sep 7, 2005 | 08:49 AM
Default Re: I have my code but my Pilot radio won't ask for it. (fcm)
Thank you for the info. I will check the switched power fuse. I already checked the constant power fuse and, as you said, it must be OK since the red light is flashing.
Thanks again.
Old Sep 7, 2005 | 07:04 PM
I found the second fuse. It was the same circuit (surprise, surprise) as the front accessory socket (a.k.a. cigarette lighter) that I was using with the tire compressor when I caused the problem. New fuse, entered code and I have music. Thank you romoracing for pointing me in the right direction.
Old Sep 8, 2005 | 06:35 PM
romoracing's Avatar
Lol, I just helped you alittle! Fcm beat me to it. He the ones that desevers the credit! But im glad you have music!
ramstrung
Sep 16, 2007 04:45 PM
REDTOPAlchemy
Sep 17, 2005 03:44 PM
slmulkey
Audio / Security / Video
Sep 11, 2005 11:05 PM
jfreeman3
Feb 20, 2005 09:40 AM
UpToWnZFiNeSt
May 10, 2003 02:20 PM
