GSR seats into a hatch
Old Sep 6, 2005 | 03:41 PM
Sprayin_civic's Avatar
Default GSR seats into a hatch
Now i've been told that integra back seats fit into EGs. I had a set of GSR rear seats and they dont even come close to fitten. So do they fit or do you have to tweak them to fit?
Old Sep 6, 2005 | 03:44 PM
94hatchling's Avatar
Default Re: GSR seats into a hatch (Sprayin_civic)
there are some how tos/DIY already around. just do a search.
as far as the back seats... for the better fitment, need the back part of the seat from a 2 door, and the bottom from a 4 door otherwise there is a gap between the two.
best of luck, and let us know how it comes out.
Old Sep 6, 2005 | 03:50 PM
Default Re: GSR seats into a hatch (94hatchling)
well the bottom part form the 4 door is whats really worng with it. The metal prong that snaps in is on the worng side and the foam is alot bigger then what the civic was so it sits higher!
Old Sep 6, 2005 | 04:32 PM
belly-eg6's Avatar
i have the same prob to been tryin the fit in some people have a perfect fit wit the gsr seats cleary i dont
Old Sep 6, 2005 | 05:28 PM
LL2009's Avatar
Default Re: GSR seats into a hatch (belly-eg6)
they do fit but not real good theres going to be a gap in the back and you have to bend the metal clips in the front .
Old Sep 6, 2005 | 06:49 PM
the metal clip is on the wrong side....
Old Sep 8, 2005 | 11:20 AM
if anyone has an answer i would rally like to hear it!
Old Sep 8, 2005 | 11:42 AM
LAWNMOWER's Avatar
A four door Integra bottom half will fit great. Its the right length. The upper parts of a two door will fit perfectly.
Old Sep 8, 2005 | 12:06 PM
WhiteSiDan's Avatar
Default Re: GSR seats into a hatch (LAWNMOWER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LAWNMOWER &raquo;</TD></TR><TR><TD CLASS="quote">A four door Integra bottom half will fit great. Its the right length. The upper parts of a two door will fit perfectly. </TD></TR></TABLE>
Old Sep 8, 2005 | 12:18 PM
I cant believe this shit's Avatar
I believe the rails have to be swapped? It's been awhile.
Old Sep 8, 2005 | 02:47 PM
JDM INSPIRED's Avatar
Default Re: GSR seats into a hatch (I cant believe this ****)
if you want to have a clean fit on your eg hatchs...then you would need to get a integra coupe rear upper seats and sedan rear lower seat...the reason you need a sedan rear lower seat because it wont have any cap between the seats...but if you just want to put the complete rear seats from coupe on your eg...then make sure you get the integra rear lower seat from 94-97 (because the clips are same as eg and the clips points on 98-01 are different)...
Old Sep 8, 2005 | 03:24 PM
Default Re: GSR seats into a hatch (JDM INSPIRED)
thank you this is helping me out alot!
Old Sep 8, 2005 | 03:31 PM
no problem at all...
95 GSR B20VTEC
11
Apr 16, 2013 01:50 AM
emoticon
Sep 16, 2008 02:44 PM
CompanyFlow
Nov 25, 2005 10:35 AM
energie
13
Jan 17, 2003 09:02 AM
xXx Justin xXx
Oct 28, 2002 11:40 AM
