97 accord "brake upgrade">>Legend conversion
I have a question!
I have a 97 accord ex! I want to upgrade my brakes, decided to go with some 2piston Legend 94-95 calipers.
Now... will they fit right on my accord? Will I need to get someone to customize some pieces or parts to have the calipers in the right position?
Along with the Legend calipers, I was thinking about some slotted (and...or...drilled) rotors.
If someone has done that "conversion", please let me know, and if could tell me where to get the parts needed (..if needed..)..
Thanks a lot!!!
Thanks a lot!!!
most of the parts can be sourced from a junkyard...the callipers themselves can be gotten from napa...just make sure you order the two piston and not the single sliding piston...as for your rotors, i wouldn't even bother with the slotted, drilled, or any hybrid of the two for a daily driver...it will only lead to the premature death of your rotors, and you will likely never see the benefits on the street...axxis ultimates are a great pad, and you can get them from cobalt friction...good luck...
gianinline
Oct 10, 2005 04:25 AM
