built d-series runs but won't rev
Old Sep 6, 2005 | 01:05 PM
powelljw's Avatar
Default built d-series runs but won't rev
i have a fully built d-16 with y8 head and p28 ecu jut got it back and in from pistons and rods balancing already had skunk stage 2 cams titanium springs and lifters msd ignition
so it starts and idles fine starts out rich but then runs just slightly lean but wont rev at all. could it be ignition timming or cam timing ? or just in need of tune ?
Old Sep 6, 2005 | 01:50 PM
Suck my DX's Avatar
Default Re: built d-series runs but won't rev (powelljw)
lol did u hook up ur throttle cable?
im messin does it not rev at all or does it rev a little bit and then seem like its hitting an early cutoff?
Old Sep 6, 2005 | 03:19 PM
turbodcivic510's Avatar
sounds liek you need a good tune and to give everything another look down make sure all your lines are lubed and nothing snagged or not connected...
Old Sep 6, 2005 | 03:43 PM
powelljw's Avatar
do p28's have to re-learn?
bcause it kinda seems like it is trying to learn right now it it is runnung full rich on the AF gauge then it will start to go lean untill it is about to stall then jump back to full rich
Old Sep 6, 2005 | 03:45 PM
powelljw's Avatar
bump
Old Sep 6, 2005 | 03:51 PM
Suck my DX's Avatar
Default Re: (powelljw)
u need to have that thing towed and get it tuned..i wouldnt really suggest driving it much till you do
Old Sep 6, 2005 | 04:16 PM
powelljw's Avatar
http://cgi.ebay.com/ebaymotors...ZWD1V
do you think that this is good for uberdata i have afriend with the wideband and burner and software
Old Sep 6, 2005 | 04:25 PM
Sepheroth86's Avatar
You can get that same kit from Moates.net
I have purchased a few kits from there.
Better to go with a known good seller than possibly get ripped off on ebay.
Old Sep 6, 2005 | 06:15 PM
powelljw's Avatar
also could a high fuel presure cause these problems ? it is running about 60lb of presure
Old Sep 6, 2005 | 06:21 PM
powelljw's Avatar
bump it up
Old Sep 6, 2005 | 06:36 PM
UltimX's Avatar
Did you get ur ecu chipped? I'v heard of people getting chips and they fubar on the program causing lack of rev.
Old Sep 6, 2005 | 08:07 PM
NikoZai's Avatar
Default Re: built d-series runs but won't rev (UltimX)
we need more information, that doens't tell me anything useful to diagnose...
What model, what was done wiring-wise?
And yeah, if you're using aggressive cams and pistons, you'll need to tune it.
And why are you building an engine if you don't know that much <-- rude.. i know..
Jabbito
Nov 8, 2015 03:24 PM
slow_srt
Feb 6, 2007 08:08 PM
LSVTEC 91 Civic
25
Oct 10, 2004 10:38 PM
Si Integra
Jan 31, 2004 08:13 AM
skilzz
Mar 12, 2002 08:55 PM
