ex cluster in std
i got an ex cluster from a 89 4door and put it into my 89 hatch and the only thing that doesnt work is the tach, what do i have to do to wire it up to work any help would be good,
well i used to have a tach but it got stolen, so maybe one of the wires for the tach got removed from the cluster i dunno. ill check into it
Should be a distinctive blue wire going into the plug that plugs into the back of the cluster, behind the tach. If it's gone, go to the wrecker and grab another wire (de pin it so you can plug it into your harness) and splice it directly into the blue wire coming off of your ignitor (on your distributor). Hope this helps!
vtechjunkie
28
Mar 16, 2010 11:14 AM
averyvm
Jul 15, 2008 01:21 PM
