Questions on Toda header
Im thinking of getting the 4-2-1 for my b16. I just need to know if I can keep A/C and also is a flex pipe needed or will a donut gasket/spring bolt combo be good enough?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">The Toda header will allow you to retain A/C, and it utilizes a standard "JDM-sized" donut gasket flexible flange. </TD></TR></TABLE>
so no need for flexpipe? Its 2.5 collector right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Junkyard2000 »</TD></TR><TR><TD CLASS="quote">
so no need for flexpipe? Its 2.5 collector right?</TD></TR></TABLE>
No, you do not need a flex-pipe. You just need a cat or test-pipe with a 2.5" flared flange. The collector is 63.5mm (2.5") OD.
