code 7 tps
Old Feb 26, 2002 | 02:32 PM
RedRacerCivic's Avatar
Default code 7 tps
i have code 7 on my mpfi swap, i have the Si ECU, wire harness and distributer on a DX block and head. Do i need to swap the green/white and yellow/white wire from the TPS to make everything work right and get rid of the code?
Also, where do those 3 wires from the TPS go to anyways? where else do they hook up?
Old Feb 26, 2002 | 03:21 PM
Mugen Dom's Avatar
Default Re: code 7 tps (RedRacerCivic)
u didnt reverse them before u plugged em in? how did u make it reach? they goto teh ecu
Old Feb 26, 2002 | 03:26 PM
CimorelliCRX's Avatar
Default Re: code 7 tps (jdmB18hatch)
You have to reverse two of the wires from the engine harness to the TPS. Cut the green/white wire, and yellow/white wire. Connect the green/whtie wire to the yellow/white and the yellow/white with the green/white wire.
So if you reverse them you should be arlight.
Old Feb 26, 2002 | 04:06 PM
Default Re: code 7 tps (CimorelliCRX)
So i reverse them EVEN though i have the Si wire harness and the Si ECU?
Zappaz
23
Oct 13, 2011 01:27 PM
jisecup
Jul 9, 2003 02:53 PM
maxim
Jan 19, 2002 06:00 PM
