hydro GSR tranny, LS project, 94+ teg axles(new)
Old Sep 6, 2005 | 08:21 AM
egizzle8
Guest
Posts: n/a
Default hydro GSR tranny, LS project, 94+ teg axles(new)
Need money for new project
b18a1(pulled from a 93)
-ARP headstuds(new)
-headgasket (new in bag still)
-valvecover gasket kit(still in bag)
-Eagle rods(arp bolts)
-JE Pistons 10.1 CR(needs rings for one piston and all others installed already)
-Block honed but one cyclinder has a light scratch
-Block was painted black
-GSR driverside mount(polished)
-Blox Intake manifold(half polished) (new)
-New CNC'd fuel rail
-Hondata intake manifold gasket
-b18A1 throttle body
-B18a1 head(two sets of cams both A1's, was gonna use one set to send out and have reground)
-alternator obd1
-OBD1 dist.
Just needs one piston installed from a botched piston install and bent a ring or unless I get another one in the mail like I'm suppose to then it'll be a complete engine. Can't get any cheaper then this for everything. I'm just so sick of messing with this and ******** scammers.
I'm located in Neenah WI so I'm willing to meet folks halfway if your in a reasonable distant. 100 miles at the most.
NOW ONLY 650 picked up!!!! I need this out and I need cash!!!
Modified by egizzle8 at 11:54 AM 9/17/2005
Modified by egizzle8 at 11:55 AM 9/17/2005
Old Sep 6, 2005 | 08:28 AM
egizzle8
Guest
Posts: n/a
Default Re: hydro GSR tranny, LS project, 94+ teg axles(new) (egizzle8)
Gimme 1400 for all of it and you've got a complete swap besides a shift linkage and clutch/flywheel. You can't even get a full b16 swap for this cheap unless it's hot.
Old Sep 7, 2005 | 03:33 AM
egizzle8
Guest
Posts: n/a
http://cm.ebay.com/cm/ck/1065-...k=URL
HT folks will get 200 off the buy it now since I'm such a nice guy. 1300 for a built LS with hydro GSR tranny with new axles. You can't get much better then that.
Old Sep 7, 2005 | 05:05 AM
gsp ej1-em1's Avatar
pmed.
Old Sep 7, 2005 | 06:20 AM
egizzle8
Guest
Posts: n/a
Default Re: hydro GSR tranny, LS project, 94+ teg axles(new) (gsp ej1)
Also have a nice size bar plate fmic(27x9x3) brand new.
Old Sep 7, 2005 | 06:53 AM
egizzle8
Guest
Posts: n/a
bid bid bid!!! 1300, how much lower can I go?
Old Sep 7, 2005 | 07:14 AM
BJOnewiper's Avatar
If you still have that tranny in another week or two, it'll be mine.
Old Sep 7, 2005 | 07:17 AM
egizzle8
Guest
Posts: n/a
Default Re: (bjo)
PM'd
Old Sep 7, 2005 | 11:21 AM
t3to4e's Avatar
Default Re: (egizzle8)
pmd
Old Sep 14, 2005 | 08:43 AM
klungemonger's Avatar
Any chance you'd sell me just the Blox intake mani? If so gimme a price shipped to business address in 48326...thanks.
Old Sep 15, 2005 | 09:20 AM
t3to4e's Avatar
Default Re: (klungemonger)
no tranny?>?
Old Sep 17, 2005 | 07:53 AM
egizzle8
Guest
Posts: n/a
Default Re: (t3to4e)
Tranny is now gone. Longblock is now even lower. 650 takes it.
KeyserSoze
May 10, 2005 09:21 PM
