running axles WITHOUT the c clamp locks??
Old Sep 6, 2005 | 07:18 AM
rolledthatho's Avatar
Default running axles WITHOUT the c clamp locks??
hey guys, me and a friend just got done swapping a dohc zc motor into his civic STD
anyway upon installation of the axles, the passenger side fit in snug and fine, but the driver side wouldnt go all the way in and sit flush... (we tried forever) anyway we removed the other axle to look through and its going all the way into the gear, so we figured maybe its just the wrong axles we'll try to use them and see what we get ( 91 std axle into an si tranny btw)
anyway through all this my friend took the clips out to see if it would go in then, he didnt put them back.. if it were my car i would have put them back in but, is it a HUGE deal? seems like the hub nut will hold it on and the lockers are just a saftey deal, but for all i know he could get 3 miles up the roads and they could shoot out...
Old Sep 6, 2005 | 08:24 AM
drdisco69's Avatar
Default Re: running axles WITHOUT the c clamp locks?? (rolledthatho)
Put the C clips back in. They locate the axle in the differential, and it's trouble waiting to happen without them.
Old Sep 6, 2005 | 08:19 PM
yea, i figured as much... thanks
Old Sep 6, 2005 | 11:35 PM
FOMULA91's Avatar
Default Re: (rolledthatho)
People told me that the size for Si axel is didderent then STD or HF DX series.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SLOASSREX &raquo;</TD></TR><TR><TD CLASS="quote">yup... hf is a 23 spline hub, along with all std's and most dx models. if youre gonna swap the tranny just use your hf axles... if you plan on puttin any amount of power to the ground later then you will need to change over to a 5 spd dx or si model hub, which has 26 splines. hope this helps!
oh eah, try to make sure if your car is 89 or newer that you get an 89 or newer tranny.;
88 trannies have diff. spline count on the input shaft than the 89-up trannies</TD></TR></TABLE>
d16a9_edcivic
Jul 18, 2008 05:51 PM
dougshatch
15
Feb 19, 2007 05:30 PM
keepitngga1
Dec 21, 2006 05:00 PM
turbohf
14
May 22, 2002 10:02 PM
