Suspension & Brakes Theory, alignment, spring rates....
my rear end suspension is extremely stiff....
Old Sep 5, 2005 | 07:46 PM
teknohatchie91's Avatar
Default my rear end suspension is extremely stiff....
Hi, I own an 89 civic. With agx's and some skunk 2 lowering springs. My rear is so stiff its, its like the shocks are not even there. When I go over some bump or something is really ****** annoying. It makes like a knocking noise. Are my shocks blown? or whats causing this? I have tried every setting of the shocks and its still ****** stiff..any advice?
Old Sep 6, 2005 | 09:21 AM
ohjolt2's Avatar
Skunk2 makes actual lowering springs? or did you get a slip on coil over? I am guessing you have the slip on coils and the sleeves are floping around on the shock, thats what all those rubber doughnuts are for.
Old Sep 6, 2005 | 11:31 AM
Default Re: (ohjolt2)
no, I've got the actual springs...
Old Sep 6, 2005 | 02:15 PM
loodood's Avatar
are you dropped? anything else you've done to modify the suspension other than agx and springs?
Old Sep 6, 2005 | 02:57 PM
AutoXer's Avatar
Default Re: (teknohatchie91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teknohatchie91 &raquo;</TD></TR><TR><TD CLASS="quote">no, I've got the actual springs... </TD></TR></TABLE>
1) They're probably very stiff as it is.
2) The AGXs probably couldn't handle the rate
3) I bet your shocks are blown
AGXs are pure garbage. I had them in my car for less than 30K with Eibach Pro-Kits, and all 4 were blown - badly. One of them, I couldn't even pull the shaft out with it in a vice. I had the same symptoms as you.
PDXHatchback
Mar 18, 2007 03:13 PM
bigBOI_92DA9
Suspension & Brakes
Sep 11, 2005 04:51 AM
ngolimit408
Nov 4, 2002 07:31 AM
PearlWhiteAccord
Jun 3, 2002 09:21 AM
jpaudio
Jan 14, 2002 12:08 AM
