Suspension & Brakes Theory, alignment, spring rates....
Im new to suspension.......will this work???
Old Sep 5, 2005 | 06:31 PM
acura_9485's Avatar
Default Im new to suspension.......will this work???
Like the topic said, i dont have much knowledge about suspension...but i was wondering, im going to be getting 15s on my 94 teg..and what i want to do, is lower the car a bit, so there wont be a huge gap between my wheel well. So could i get eibach springs, and lower it w/that, without having to buy shocks struts, coilovers..all that stuff?...and if i did it this way, will it be bouncy??>.i dont want that..just a nice snugg fit.......yes im a noobie to susupension......alright thanks a lot.
Old Sep 5, 2005 | 06:38 PM
ohjolt2's Avatar
Sounds like you should get a prokit. Its a lowering spring by eibach. The shocks will depend on your wallet, but konis are your best bet if you can afford them.
Old Sep 5, 2005 | 06:52 PM
Another_EK_Hatch's Avatar
Default Re: Im new to suspension.......will this work??? (acura_9485)
prokits are OK. they won't reduce the gap all that much. when i had them on my EK i had a 2 finger wheel gap. if you want to go a little lower, then get the eibach sportlines.
Old Sep 5, 2005 | 07:45 PM
chinese acrobat's Avatar
Eibachs pro if ur goin to run on stocks.
Old Sep 6, 2005 | 09:46 AM
ohjolt2's Avatar
Seems like the sportlines are not stiff enought to keep you off the bump stops for how much drop them give. Althought the prokits might not keep you off the bumpstops if you get crazy.
Old Sep 6, 2005 | 07:34 PM
acura_9485's Avatar
Default Re: (ohjolt2)
so can i still keep my struts, shocks tho, if i just wannna get lowering springs??? whats the best for my usage??..just want to lower, not be bouncy, and have a clean look?
00siboy
Suspension & Brakes
Jan 27, 2011 04:24 AM
armintheman
Sep 28, 2010 11:00 AM
amej8
May 2, 2006 11:32 AM
96lude_srv
Apr 3, 2006 05:59 AM
Civic97s
Suspension & Brakes
May 8, 2005 05:02 AM
