Can someone clear up Manifold/TB port matching?
Old Sep 5, 2005 | 05:35 PM
Junkyard2000's Avatar
Default Can someone clear up Manifold/TB port matching?
I already searched and keep getting different answers. I thought the TB needs to be bored to the same size as the manifold inlet. But some people are saying it needs to be 1-2 mm less. So if im going with an aebs which is 65...should i get the TB bored to 63-64 or 65?
Old Sep 5, 2005 | 05:46 PM
ferio 95's Avatar
Default Re: Can someone clear up Manifold/TB port matching? (Junkyard2000)
the idea is to reduce bottle kneck. you just want to be able to not have a obviously noticeable area that air cant smoothly pass over, such as having a 65mm back side of the throttle body and a 60mm inlet to the manifold.
Old Sep 5, 2005 | 05:58 PM
Default Re: Can someone clear up Manifold/TB port matching? (ferio 95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ferio 95 &raquo;</TD></TR><TR><TD CLASS="quote">the idea is to reduce bottle kneck. you just want to be able to not have a obviously noticeable area that air cant smoothly pass over, such as having a 65mm back side of the throttle body and a 60mm inlet to the manifold.</TD></TR></TABLE>
So as long as the manifold is bigger than the tb youre ok?
Old Sep 5, 2005 | 06:20 PM
Combustion Contraption's Avatar
This will create a small amount of turbulance and slow the air down a tiny bit before they enter the runners, but its not as bad as the other way around.
Old Sep 5, 2005 | 06:55 PM
Default Re: (LsVtec92Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsVtec92Hatch &raquo;</TD></TR><TR><TD CLASS="quote">This will create a small amount of turbulance and slow the air down a tiny bit before they enter the runners, but its not as bad as the other way around.</TD></TR></TABLE>
so best bet would be to have the same size as the inlet right?
Old Sep 5, 2005 | 09:33 PM
Yep, with a slight taper from the opening of the throttle body to the butterfly valve.
Old Sep 5, 2005 | 10:49 PM
coo thanks!
ix3mydc
Oct 27, 2009 08:30 PM
B18c1-Integra
13
Feb 22, 2008 05:34 PM
racereaper7
Sep 4, 2007 09:57 AM
Audrius Z
Aug 11, 2003 06:35 AM
TurboB18C1
May 19, 2003 05:08 PM
