Problem with Sir cluster in 88 rex si
i got everything working, including the speedo running a vss, but i just tee'd into the speed signal on the cluster, but im getting a cel for no vss to the ecu. its on the oem si ecu. so is there an input and output on the cluster or what do you think is wrong, thanks for the help.
