Did compression check!?
Well i did a compression test on my 94 accord and i came up with 190 all the way across.... now when i was searching for compression results i saw that the general range is between 175-195.... Do my results being on the high end mean anything special?
You're in good shape. Generally, your looking for consistency between cylinders.
IE: A low cylinder among three good ones would indicate either bad rings or leaking valves; but you had neither
P
P
Droppedatbirth!
15
Feb 2, 2004 06:36 AM
