DIZZY SWAP NOW CAR WONT START?
Old Sep 5, 2005 | 08:12 AM
b16a27's Avatar
Default DIZZY SWAP NOW CAR WONT START?
Ok heres what happened i put my dizzy on my friends car off my car to see if it would start it didnt so then we put it back on my car and it wont start what can it be
Modified by b16a27 at 11:11 AM 9/5/2005
Old Sep 5, 2005 | 04:50 PM
Do_Ster's Avatar
same thing happen to me a little while back ago, it was my ignitor (ICM, ignition control module). i suggest you go to a junk yard or call some local tuning shops to see if you could buy a dizzy off of them
Old Sep 5, 2005 | 04:56 PM
e jay one's Avatar
Default Re: (Do_Ster)
either that or you put it on 180 degrees off.
Old Sep 5, 2005 | 06:34 PM
94Delsol d15's Avatar
Default Re: DIZZY SWAP NOW CAR WONT START? (b16a27)
Are you getting spark? If you are then like stated above you prob put the Dist on 180 Degrees out.
Rotate the motor till #1 piston is at top dead center and your timing marks line up. then install the Distributor with the rotor pionting to #1 spark plug wire.
Terry
Old Sep 5, 2005 | 06:37 PM
90ZCREX's Avatar
Default Re: DIZZY SWAP NOW CAR WONT START? (94Delsol d15)
the dizzy will only go on one way, you prolly got your plug wires on wrong
Old Sep 5, 2005 | 06:43 PM
Luserkid's Avatar
Default Re: DIZZY SWAP NOW CAR WONT START? (90ZCREX)
Fins are 180 fix that and your set.
Tommy818
28
Oct 22, 2012 10:00 AM
91EF919
Mar 31, 2011 10:15 PM
LMdb2teggy
May 24, 2010 12:29 PM
gsrpedro
Dec 5, 2008 11:42 AM
andrew714
Dec 13, 2007 09:35 PM
